LamLock is a clear flowing epoxy adhesive specifically designed for laminating Granite, Marble, Engineered Stone, etc. This is a structural epoxy with excellent strength. Because this glue drys completely clear, it is easy to color match your stone.
This glue sets up fast. Although it still takes up to 12 hours to cure, after one hour it is hard enough that you can use power tools on a lamination glued with it! If you are tired of glue setting up slowly because your temperature is colder then you will love this glue. While it still will not harden at 40 degrees Fahrenheit, from 50 - 72 degrees it is one of the fastest hardening epoxies available and it is strong with excellent adhesion. It really locks in your laminations, and that's where it made its name - Lamlock.
Tack Free in 25 minutes
Workable in 1 hour
Cures in 12 hours or less!
2 to 1 mix
Dries crystal clear
LLCC3G LamLock 3 Gallon Kit normally sells for $199.95, on sale for only $169.69
LLCC3Q LamLock 3 Quart Kit normally sells for $79.90, on sale for only $ 69.90
Slayer 4" Flat Coarse Cup Wheel
These 4" x 5/8 grinding cups are made to give you the longest life and most aggressive material removal when grinding hard granite! We field tested these with some of our customers and they love these Slayer grinding cups! Slayer - For Killer Performance!
Engineered vibration free
Dry cutting
Excellent for shaping granite and other natural stone
SFGC4C Slayer 4" Flat Coarse Cup Wheel. Normally sells for $59.90, on sale for $49.90
You can order by PM, email or a simple phone call!
