So, on to figuring out the repair. The first one is already loose enough that it will probably just fall out when the silicone around the cabinet face is cut. Clean up the epoxy in the seam, add new epoxy, replace piece, and finish.
The second one however is severely cracked on the right side of the sink and has a hairline fissure on the left. I believe that trying to do the same thing as the first will not result in the same outcome. I suspect that the cracks will lead to breakage if any attempt is made to remove the piece. I recommended that they replace the whole top. But as a temporary fix, I was hoping to add supports to the edge and add some type (not sure what type) of flowing adhesive to the major crack to stabilize it for awhile.
Has anyone out there tried this or has any suggestions?
Many thanks ....
(Yea, yea, I know, join the SFA and solve world hunger. I'll get there, just a little strapped for cash as the moment.)
