Hello
We are about to cut holes in our North Wood cnc tables to start running hard stops. I have ordered the reference stops from blick with a 12mm pin . Anybody have a table layout I could steal? I used to run CMS Brembana Max and want to lay out something similar to that. If we do it right I can start adding the minimum for stock removal on position 0 and skip finger bits all together. Any info you have would help.
Table Layout
David G Stout
Belmarmi
cad@belmarmi.com
904-699-6752
Belmarmi
cad@belmarmi.com
904-699-6752
Re: Table Layout
Call robbie at NW. I think he ran a groove in a table as a positive 0,0 line and may have the bit you can borrow. I don't think holes will be very flexible as they will be 1" too long for whatever piece you want to put on the table.
I think Mike Dean also did this to his table. Maybe he will chime in on how it is working out for him.
Re: Table Layout
Yeah like i said I have ran CMS machines for years. I dont want to be locked into edges of table since we are always loading the whole table all the time. I will always need a piece in the center.
David G Stout
Belmarmi
cad@belmarmi.com
904-699-6752
Belmarmi
cad@belmarmi.com
904-699-6752
