Epoxy bleeding into white marble
Wondering if anyone out here knows a way to draw out the bleeding or minimize it. We have an Island that has a small spot on the mitered edge that looks to have bleed into the marble. Also what epoxy is everyone using on mitered white marble?
GREAT LAKES GRANITE WORKS
3980 West River Dr
Comstock Park, Mich 49525
(616)785-3088
Jeff Lixey Plant Manager
3980 West River Dr
(616)785-3088
- ageless
- Been thanked: 89 times
Re: Epoxy bleeding into white marble
we have been using the touchstone glacier for marble ( and other stones) and we like it.one of the reasons i like the glacier over the glax is that the mixing ratio is not as critical. we also use integra magic for seams.
- Been thanked: 31 times
We have been using Integra Transparent White, it already comes mixed and does not bleed. It works perfect for marble miters and laminations.
Jonathan De la Rosa
delarosajr1@gmail.com
Thanks i will do some R&D on these. How about drawing out bleeding of a piece already made?
3980 West River Dr
(616)785-3088
3980 West River Dr
(616)785-3088
We switched to Bonstone Touchstone Glacier. It's a urethane. Doesn't bleed and is UV/moisture stable.
I dont know of a way to pull that out. but then I have not really tried either. maybe someone else has found a way
Hit the bleed lightly with a torch and immediately wipe with acetone. I've minimized some bleeding using that method... We use Tenax Crystal for white marble miters exclusively, but we just hit the edge with a bit of sealer first to stop this from happening. And we miter a ton of white marble.
Heat,then use acetone to draw it .will fade but wont remove.
MICHAEL CHEANEY SFA MEMBER
