How to Hone white Carrera marble
- Been thanked: 18 times
Hey everyone, I have a customer that wants her polished white carrera marble to be honed and I'm not sure how to do so. Any procedures need to able to do e on site without removing the countertops. If anyone has any suggestions I'd love to hear them.
Re: How to Hone white Carrera marble
random orbital sander with sandpaper and then finish with Cams honing powder.
if you have to get into corners and tight to the walls you also might have to use an oscillating tool like the fein multimaster with the triangular sanding pads
This!!!!luke getz wrote:finish with Cams honing powder.
Order this first.
Purchase from the man himself:Mtodd62406 wrote:Where can I purchase Cams honing powder?
http://www.easystonecare.com/Soft-Cut-2 ... /sc220.htm
Get yourself a 220 grit resin pad from Cameron with the honing powder. Run the resin pad with a knuckle dragger at about 600 rpm then use the honing powder with the white pads Cameron has. Super easy
Lester Swick
908-418-5925 cell
LSwick1968@Gmail.com
TEAM BUBBA BOATER
908-418-5925 cell
TEAM BUBBA BOATER
Thanks for all the feedback guys, and the links are greatly appreciated seeing how there's a million different products out there. I can't wait to try it out and when I do I'll let you know how it went.
The easiest way to hone this marble is 2 steps.
1. Cut with a 220 resin pad until it is all consistent and even.
2. Hone with the Soft Cut honing powder and a white pad.
Rinse with water/sponge and buff dry. Seal it with a good impregnator.
- skulptor007
X2! I've used the above on natural quartzite to, works great. Cam really knows his stuff and shares it freely, great guy!
Greg Bergmann
Soapstone Werks
Www.soapstonewerks.com
760 739-0655
2534 E.El Norte Pkwy
Escondido CA
Soapstone Werks
760 739-0655
Escondido CA
Can you send me a link to the resin pad you think I should use. Sorry for being so needy, I'm just trying to make this process as streamline as possible and I want to shop for the best products.
There is a 1000 times more info in the member area. Think about joining....
I would recommend this resin pad for the Carrara: http://www.easystonecare.com/Resin-Diam ... -p/mr5.htm
I also strongly agree with joining the SFA.
- Has thanked: 39 times
X2Stone Dude wrote:I would recommend this resin pad for the Carrara: http://www.easystonecare.com/Resin-Diam ... -p/mr5.htm
The only regret you'll have will be over not joining sooner.
Colby Douglas
Bella Terra Stone
North Bay, Ontario, Canada
705-358-3039
www.BellaTerraStone.com
Bella Terra Stone
705-358-3039
Muriatic Acid with water 50/50, apply and swipe.
Juan M. Flores
Travertine Stone Products, Inc.
Imports, Fabrication & Installation of
Stone Countertops - Architectural Stone - Tiles
1300 S West Dr.
Leander, Tx. 78641
Of. 512-528-9999
Mb. 512-247-8111
Fx. 866-811-0193
www.travertinestoneproducts.com
1300 S West Dr.
Leander, Tx. 78641
Of. 512-528-9999
Mb. 512-247-8111
Fx. 866-811-0193
Using acid is a tricky deal in a confined finished space.
After the acid solution is applied & thoroughly rinsed, a neutralizer is required to stop the process. Then a clean water rinse.
1. Be careful to capture all of the contaminated water, as it could damage surrounding finishes.
2. Acid honing can leave an uneven finish.
3. Using acid requires effective protective gear.
4. Disposal of the waste water can be an issue, because of the acid.
Acid is a poor choice for this type of project, IMO.
Agreed - This is an installed project in a home. Not in a shop. Before using acid you need to be open an honest with the customer about the process.
jmtravertine@gmail.com wrote:Muriatic Acid with water 50/50, apply and swipe.
This is terrible advice. Muriatic 50/50 in a kitchen is not safe and is a huge liability. I wouldn't recommend doing this. This is absolutely reckless.
if you have never used muriatic acid, I would not even attempt this inside a home. we used to use very diluted muriatic acid to remove grout haze on tile years ago, and I had some interesting experiences with it - the fumes from muriatic acid will rust any exposed steel - I opened the back of my truck one morning to find every single tool in my truck with a coating of rust because there was a very small amount of muriatic acid in a bucket that could evaporate.
I used Heavy Duty Cleaner I got from the Tile Shop. Main ingredient is phosphoric acid. It did a tremendous job. I ended up filling a little more than above the tile in a galvanized tub and setting the tile in for a few minutes each and then rinsing off. (before installation). It's a bathroom floor so the polished finish was not wanted.
not sure how it would work on a countertop because you want to let it soak (and fizz) for a few minutes. Suppose you could border the top somehow.
Also I went through about 6 bottles for 50 or so 18 x 18 tile. When it stops fizzing you've probably exhausted the active acid.
Good luck and wear all your PPE
