As I was leaving he threw one more dig at me so I told him that I took a picture for proof in case of an accident and that he would have a law suit on his hands.
HA!Dan R. wrote:![]()
You may need to speak to his boss, his wife.
I would say yes to that.Ken Lago wrote:Would my sissor clamp be safer for 2cm?
I thought you said simplified.....Omni Cubed Larry wrote:Here is my simplified Larry speak.![]()
Even if the slabs are perfectly flat and even if they don't have any fissures, it still comes down to the functional geometry of the clamp and the amount of friction you have between the clamp and the stone. This is also why they are rated for certain slab thicknesses.
The force (or weight) the clamp can lift is the Coefficient of Static Friction multiplied by the Normal Force. f=uN
The Normal Force is the force perpendicular to the slab, so in this case it is the Clamp Force. But the Clamp Force is a function of the weight of the stone and the functional geometry of the clamp. The Coefficient of Static Friction is related to how "grippy" the rubber is and how "slippery" the smooth (and often dusty) stone is (it is a number that relates to the interface between the two materials and how easily they slip past each other). It also happens to affect the Clamp Force but that is more complicated. When you reduce the Friction you reduce the Clamp Force. Clamping two pieces of stone together effectively means you have half as much rubber per slab, and the slab-to-slab Friction is much lower than slab-to-rubber Friction. Fortunately there is a safety factor designed into these clamps, but you are asking for a higher potential for danger whenever you reduce the Friction by either picking up very dusty slabs or by picking up multiple slabs or by using a clamp with messed up rubber, etc.
There are also dynamic forces in play. When ever you drive over a bump, the vertical load the clamp and slab experiences can be multiplied greatly. So, if you pick up two slabs and everything "seems" fine, but in reality it is barely holding the slabs, they could drop when you hit a bump because of the multiplication of the load due to the up and down motion of the boom.
Omni Cubed Larry wrote:Don't be a fool, safety glasses are cool!
I was going to say almost the exact same thing;2 slabs = BOOMOmni Cubed Larry wrote:Too often slabs are very warped, so clamping "forcing" them together when they are warped is not good. Causing a fissure near where the clamp is could spell disaster for the next lift or the next person.
Just because it has worked for you and you haven't had an incident, doesn't mean that it is not risky. Sometimes no incidents make us complacent to the real danger. Kind of like the guy who grinds without safety glasses for two decades without incident.Don't be a fool, safety glasses are cool!
