IT IS COLD ... WHAT HEATERS ( 120 V ) ARE YALL USING ON JOBSITES ?
- Troy Burnette
Guys ,
Anyone have a 120 v electric heater that they are using on job sites that your guys like ?
- Has thanked: 41 times
- Been thanked: 35 times
Re: IT IS COLD ... WHAT HEATERS ( 120 V ) ARE YALL USING ON JOBSITES ?
The houses all have to have heat up here. Drywallers need it
Brian Andre
ANA Granite LLC
Flint MI
brian@anagranitellc.com
“We are all born ignorant, but one must work hard to remain stupid.” ― Benjamin Franklin
ANA Granite LLC
Flint MI
I've been using these. They work great! http://www.mrheater.com/product/heaters ... eries.html
- Been thanked: 83 times
We use a turbo heater. I hate the smell of them but we only use them when we have to which is not very often.
Tim Farr
Stoneworks of Augusta, Inc.
3843 Wrightsboro Rd
Augusta, Ga 30909
706-798-3005
3843 Wrightsboro Rd
Augusta, Ga 30909
706-798-3005
graniteman wrote:The houses all have to have heat up here. Drywallers need it
x 2
- Has thanked: 71 times
- Been thanked: 41 times
Dan R. wrote:graniteman wrote:The houses all have to have heat up here. Drywallers need it
x 2
X 3
You obviously are not throwing a big enough hissy-fit.
Be sure to add in a lot of phrases about seam integrity, proper adhesion, warranty requirements etc... It will make it seem like we care more about the final product than our personal comfort.
DAVE WORRELL
Pres. Innovative Stone
(530) 362-0779
email: dave@innStone.com
website: http://www.InnStone.com
(530) 362-0779
X4innstone wrote:Dan R. wrote:graniteman wrote:The houses all have to have heat up here. Drywallers need it
x 2
X 3
You obviously are not throwing a big enough hissy-fit.You do that right, the builder will heat the place just to not hear you again. Were you never a teenager?
Lost a few accounts back in the 70's & 80's because of this, but it was worth it by the late 80's all the builders were trained to have heat.
All of you please keep in mind where Troy is located. South Mississippi. Cold there is anything below 50 degrees.
Why would it make a difference where he's located? If heat is needed someone has to supply it. Around here it's the builders responsibility to have the building ready for the subs.
kevinp wrote:Why would it make a difference where he's located?
It was only a joke about what they perceive as cold.
I don't know of an electric heater that would make a difference in a cold house. We use propane torpedo heaters indoors all the time. They are noisy but don't stink like the kerosene/diesel fuel ones. A 20lb propane tank would last 3-4 hours and heat an entire kitchen quickly. You will also need 120v electric for the ignition and fan.
Brian Andre
ANA Granite LLC
Flint MI
ANA Granite LLC
Flint MI
Darryl Miller wrote:kevinp wrote:Why would it make a difference where he's located?
I'm a little slow to catch on!
X2graniteman wrote:I don't know of an electric heater that would make a difference in a cold house. We use propane torpedo heaters indoors all the time. They are noisy but don't stink like the kerosene/diesel fuel ones. A 20lb propane tank would last 3-4 hours and heat an entire kitchen quickly. You will also need 120v electric for the ignition and fan.
Especially a 120V (small) heater.
x3Mark Meriaux wrote:X2graniteman wrote:I don't know of an electric heater that would make a difference in a cold house. We use propane torpedo heaters indoors all the time. They are noisy but don't stink like the kerosene/diesel fuel ones. A 20lb propane tank would last 3-4 hours and heat an entire kitchen quickly. You will also need 120v electric for the ignition and fan.
- Troy Burnette
