dear members
I have a lot.of customer coming in to cut ceramic skirting and borders for flooring. problem is when we cut with bridge cutter or any marble cutting machine the edge chips. when we cut with waterjet it comes good. is their any way we can get good cut without waterjet cutting.
Regards
Yusuf
cermaic granite cutting
Re: cermaic granite cutting
Two things,
1. If you use a continuous rim blade to cut the ceramic, you shouldn't have the chips.
2. Check your private messages.
Electro plated or continuous rim should help for sure
Jason Lagerquist
Owner
Finishing Touches Restoration
Ferryville WI
Owner
Ferryville WI
Seconded on the continuous edge blades, and go very slowly using lots of water. Ive seen this stuff melt when dry cut.
Also when we're line polishing and smoothing the overhangs, we cut a very small arris into the edges. This stops it chipping so much. Not much you can do at the bridge saw stage but progress very slowly and hope it doesn't break, as far as im aware
Needless to say, everyone hates working with it.
Ben Brecevic
Wet Polisher Slinger
Contemporary Granite and Marble
Beenleigh
Australia
Beenleigh
Australia
