Hello Stone Cutters its me the Stone Cutter called yoda
whats the procedure theese day for a chip at sink?
appreciate your comments
Curtis
Sink chip restoration
- Curtis R. Marburger
- Been thanked: 54 times
Curtis R Marburger
Middletown PA
Middletown PA
Re: Sink chip restoration
We use Fill-A-Chip.
fill with glue
cover with non sticky side of scotch tape
Cure with UV light
scrape edge
scrape top
gently sand/polish arris
fill with glue
Cure with UV light
scrape edge
scrape top
Shameless plug: http://www.easystonecare.com/FillaChip- ... -s/239.htm
Curtis:
It depends on how big the chip is. Fillachip works great, but if you've got the time and inclination, nothing beats pulling the faucet and reprofiling and polishing the sink cut out. The chip isn't repaired; it's nonexistent. And much less likely to recur than it was with the cheap pencil edge.
