Best Machine To Start Out With
If you were just starting in the industry what would be your first purchase?
I’m going to be entering this market and (thank god) found this resource of SFA. I have a shop that does laminate and solid surface and would like to get into stone, mainly quartz. I don’t foresee a tremendous amount of volume like some of the others on here. But hopefully some day we will get to that level. We are connected with a lot of home builders and I want to be able to offer all surfaces to them under one roof. Right now I am losing the stone work and I know I can pick up a few new ones if I offer everything in house.
So my question is, what do you think is the most valuable way to make a real attempt at entering the market without spending a fortune. After reading this forum all weekend my plan so far is to find bridge saw and a sink cutter like the Ghines systematic. And do the rest manually. But would I be better spending a little more and getting a used 5 axis saw? I’ve read the Ghines machine wont do corner sinks which is a problem because I’m doing them all the time now in the other surfaces so my area must be partial to corner sinks? Also in my area we see tons and tons of L shape kitchens which will be difficult without a water jet maybe?
How about a leather finish? Can you do that with hand (wet)polishers?
My goal is 2 kitchens a week. It will start out much slower than that I’m sure but in the past whenever we have gotten into something new it starts slow but builds fast. My budget is under 100k but that needs to buy all the hand tools as well.
Any advice is appreciated and thank you.
Re: Best Machine To Start Out With
The best advice I can give you is to spend the first $100 of that budget on an SFA membership. This will get you into the Member's Lounge where there are a multitude of discussions on this. You also need to attend the workshops. They are free of charge, you cover your travel and lodging. Also fill out your signature line so we know who we are talking to. You may be able to find a member close to you that will allow you to visit their shop to see what machines they have and how this is done.
I started out with a bridge saw and hand routers and then later got a CNC router for edges and sink cutouts. We ran that way for years and upgraded to a 5 axis saw two years ago.
I'll add to this.
Started out with a blue ripper track saw, then bought a used bridge saw and we are now in the process of buying our first 5 axis. Start slow, low cost is the best advice I can give. Unless you jump in full bore ready to go full time stone, then do whatever you want.
Hanu B.
Surface Setters
Savannah, GA
Surface Setters
Savannah, GA
We have a 5 axis saw for sale that will be in the "start slow" price range. It's listed in the classifieds if you want to see some pictures.SurfaceSettersInc. wrote: ↑Mon Jul 29, 2019 3:30 pmI'll add to this.
Started out with a blue ripper track saw, then bought a used bridge saw and we are now in the process of buying our first 5 axis. Start slow, low cost is the best advice I can give. Unless you jump in full bore ready to go full time stone, then do whatever you want.![]()
viewtopic.php?f=44&t=29399
Buy Guy's saw and you will never need another until you are past 15 kitchens a week.
Can a 5 axis saw cut sinks? I guess more importantly if yes is how does that big saw cut vanity holes? And inside L’s?
- Has thanked: 15 times
Suggestion: Poll your existing customers and develop an estimate of how much work is already out there for you. If you underestimate significantly you will quickly find yourself looking to replace your original purchases.
If you can get 4 or 5 kitchens a week I'd recommend a used bridge saw and a used but inexpensive CNC like a Park Destiny. If that's too big a bite to start with get the used bridge saw and a Wizard. I was doing almost $2M in sales with a wizard for my sink machine before I got a CNC.
If you like shoot me a PM and we can discuss your options. Lots of questions to answer about volume, work mix, lead time, your existing physical plant, and the like before you decide on machine purchases.
mark s.
mark s.
Mark S.
Custom Stone Interiors
St. Cloud MN
St. Cloud MN
- Has thanked: 25 times
- Been thanked: 26 times
Have you considered building your sales by outsourcing the fabrication for a bit while you learn the install side of things? Several successful months/years of this could stretch your budget and you'd have some volume to rely on for Day 1 of your fabrication venture. We did that for almost $2M per year. Its nice to have work waiting when you fire up the machines.
Find someone local with some inventory that you could sell from.
Matt Kraft
Custom Marble Inc.
Millstadt, IL
618.476.1345
matt (dot) kraft@custommarble.net
Custom Marble Inc.
Millstadt, IL
618.476.1345
I have a small sink cnc that cuts a perfect sink. I actually have 2 and will be selling them, as we are moving up to a larger machine. Complete with tooling and we will train, as needed.
I'm only in the research stage at this point, I'm thinking sometime next year for a target date. I just became a member also so as soon as I'm active I will look more in the members area. Some good info I have received and I am revising my plan.
sinks can be cut by hand best use of money in the beginning is definitely a bridge saw then some type of flat edge machine like a marmo lcv 711 or sasso flying flat (i know there are others these are just examples) and push the flat edge as a standard (most new build tracks offer flat as a standard everything else is upgrade) with that you should be able to do a couple kitchens a day with a few shop guys and a couple installers.
Evan Shootkevich
Artistic Stone Works Lodi, CA
209-369-6449
209-369-6449
