Yes, I know, don't stop by unless you need something.
Wow 48 GPM is a ton of water! Thats a small waterfall. You said it is a "steam" shower: Does it have a steam generator or are they referring to a shower with heated surfaces? If it has a steam generator every connector needs to be waterproofed, along with whatever lighting should be underwater rated at a minimum. Steam permeates everywhere whether you want it to or not.Jeff Leun wrote: ↑Sun Oct 25, 2020 2:25 pmThanks Mark, I've hit a few walls with this as you would expect.
Matt, That's generally the line I am taking. The LED from DeFusco isn't waterproof. The shower plumbing unit will put out 48 gallons a minute. I have to be 100% sure water won't affect the panels, too much risk too assume they won't get damp at minimum. I got in on the end of the design so I'm running out of time to make this all work like they want.
My idea is a rather simplistic approach so I'm surprised it's not being done. Lumen output is the hang up but there are workarounds. I may have to table this design for the future.
The Steam generator is under the house, they thought about dropping a boiler in but the house was 75% complete when they bought it. 5 Instant hot units to run the shower which is 8x8 and in todays world isn't big anymore.gssfabrication wrote: ↑Tue Oct 27, 2020 12:32 pmWow 48 GPM is a ton of water! Thats a small waterfall. You said it is a "steam" shower: Does it have a steam generator or are they referring to a shower with heated surfaces? If it has a steam generator every connector needs to be waterproofed, along with whatever lighting should be underwater rated at a minimum. Steam permeates everywhere whether you want it to or not.Jeff Leun wrote: ↑Sun Oct 25, 2020 2:25 pmThanks Mark, I've hit a few walls with this as you would expect.
How warm do the surface of the heating elements get? If you are putting them next to the lighting panels it may kill them in short order. LEDs + Heat = Shorter lifespan.
Luckily the water will do some secondary cooling compared to the heating elements the question is it enough to keep the lighting elements at a temp they are rated for. You might have to put a conductive clear layer between (glass?) the elements and the light panels with the stone on top and hope the layer (glass comes to mind) conducts heat to the stone and not the lighting elements.
You could put some Aluminum backed insulating tape/foam on the back side of the light panels to further protect them. I would want to build a sealed mockup of the butt portion (seat) with a temp probe/sensor right by the panel to get an idea what these panels are going to be exposed to. LEDs when overheated go from a lifespan of 1,000s of hours to 10s or 100s of hours.
Years ago I did some detector work with lightpipes and after polishing the outsides we painted them with a reflective paint to get the most light to the sensor. I wonder if you could do the same by lighting the sides of a piece of glass/lexan and painting the back (or maybe just mirror glass) to reflect the light to the surface that is cleanly bonded to the stone to maximize light transmittance. It does not have the same effect as back illumination however you could get some powerful light drivers for the sides and then avoid putting the heating elements directly beneath the light panels. To diffuse the light the glass might need to be frosted. Just some of my thoughts.
Good luck,
Rick Graff
