caesar stone repair
Had to hand cut an inside corner yesterday, blade got caught and jumped hitting the face of the caesar stone. This made a small groove in the surface--- has or does anyone have the best solution to fix this other than recutting, This would cost me another slab.
John B.
White Plains Marble, Inc
186 E. Main Street
Elmsford, NY 10523
(914)347-6000
186 E. Main Street
Elmsford, NY 10523
(914)347-6000
Re: caesar stone repair
John, ask that question in the members lounge and you will get answers. You are a member right?
its a savable mistake if your not a member yet PM me we are all about helping out fabricators in need i can call you or you can call me E.S. is extremely easy to fix
I have had success layering different colors into the area that match the particulate of the stone with polyester knife grade and razor blade it down to the surface. If it is not shiny enough then you may need to do a top coat of CA.
Should be an easy fix if it is not one of the fine grained es materials. Those can be harder to match.
