Gmm tecna problem
Posted: Sun Oct 14, 2012 7:43 pm
by santanota
Hi guys
Could you give me a hand?
In my screen pop up a window that says:
"intervento del dispositivo di controllo Usura chiocciole
Consultare libro istruzione
Premi esc"
I'm located in Colombia and we don't have any Technician of Gmm around here
What should I do to fix or repair my machine
Looking forward your comments
Re: Gmm tecna problem
Posted: Sun Oct 14, 2012 8:03 pm
by mikedean
That translates to:
intervention of the control device Wear snails
Refer to instruction book
Press esc "
Not sure what kind of snails...
someone might know better.
Posted: Sun Oct 14, 2012 8:06 pm
by GuyboR
Per Google Translate
"intervention of the control snails Wear
Press esc
I think the "snails wear" part is incorrect though. :lol:
Who did you buy the machine from? Email / call them. Otherwise email GMM Italy Support. Their Monday starts in a few hours.
http://www.gmm.it/uk/gmm_contatti.asp
Posted: Sun Oct 14, 2012 8:09 pm
Call Salem or GMM . It seems like a communication or connection error. I know just enough Italian to be wrong.
I think it says control wear nuts. I first thought it to be a motorboater term, but it may refer to a mechanical part.
Posted: Sun Oct 14, 2012 8:49 pm
by santanota
I thank for your post guys
the manual refers to the snail of the head ( up and down of the blade)
I bought this machine as second hand but the machine was inspected before shipping to Colombia
I'll email to Gmm in Italy
Posted: Mon Oct 15, 2012 7:12 pm
by santanota
Hi guys,
I Solved my problem, it was some dust on the snail
I want to share the response from Gmm
"Hello,
Alarm is for the lifting  nut that can maybe be worn out.
Try this:
1-    go up on the head of the machine and check if there is something pushing the limit switch that refers to the nut protection, sometimes it happens that the metal plate fixed on the safety nut has been angled so pushing the limit though the nut is ok. Some other times there was dirty pushing the limit (piece of stone or of wood or other), after cleaning, everything was then ok.
IF YOU FIND NOTHING OF THE ABOVE, THEN TRY THIS:
 2-     Remove the cover where "LEXTA" is written on, then remove the little cover which is under it, this to have the possibility to look at the nut from "the inside".
Finally, if it is possible keeping the start pressed, raise the head to the up limit switch, then look inside the nut to check if the thread is worn or not. IF YOU CAN'T RAISE THE HEAD, the put something below, thus to raise the head using a sort of "lever". If you can raise the head maually 3mm or more, then the nut should be replaced.
Let us know, in case we send a quote for a new lifting nut"
Posted: Tue Oct 16, 2012 6:55 pm
by JOHN_T
Should definetly replace nuts if head can not be raised . Wish it was that easy :lol:
Posted: Tue Oct 16, 2012 7:41 pm
by VThartzog
"Dust on the snail" sounds like it could be a personal problem :lol:
