best outdoor adhesive
What would be the best outdoor adhesive for laminating ?
Anastacio ortuno
IQ Granite & Flooring
1306 Washington st
S Houston,Texas 77587
(O) 281-888-7558
(C) 281-904-1781
IQGRANITE.HOUZZ.COM
IQGRANITE@GMAIL.COM
1306 Washington st
(O) 281-888-7558
(C) 281-904-1781
IQGRANITE.HOUZZ.COM
IQGRANITE@GMAIL.COM
- Mark Smith
- Has thanked: 115 times
- Been thanked: 30 times
Re: best outdoor adhesive
Depends on if you want it to be uv stable. Do you want it to change color? Because if you use run of the mill indoor epoxy that will happen. Or do you want it to stay clear etc..........Also what material are you laminating?
When laminated pieces are left aside my shop exposed to the sun the lamination tends to always fall off. We have used flow polyester for outdoor applications but want to use something superior that for a pending 120 s.f outdoor kitchen job. Stone is Solaris
Anastacio ortuno
1306 Washington st
(O) 281-888-7558
(C) 281-904-1781
IQGRANITE.HOUZZ.COM
IQGRANITE@GMAIL.COM
1306 Washington st
(O) 281-888-7558
(C) 281-904-1781
IQGRANITE.HOUZZ.COM
IQGRANITE@GMAIL.COM
- Been thanked: 25 times
Touch Stone Epoxy knife grade
Terry Roberts
Fabricator SFA
Lincoln CA 95648
916-595-3324
Fabricator SFA
Lincoln CA 95648
916-595-3324
I agree with Terry. Even if the epoxy yellows, it will not matter on that stone. You should investigate the type of resin used on the slab of Solarius. An improperly resined slab will make the correct laminate glue a moot point. Do your homework, all of it. Don't necesarrily believe the the distributor, as he probably only knows what his supplier told him. Dig as deep as you can to discover the the type of resin used. Educate yourself.
The only uv stable resin I know of is Glax by Tenax, and its 100% clear.
Glaxs is a urethane, not a resin.
Bonstone makes Last Patch Gel, which is by far the best for exterior (along with Glaxs) as it is a urethane. UV stable, won't shrink or yellow, but it's not cheap.
Otherwise I would go with something like Bonstone, Tenax, or Stone Weld epoxies.
Excuse me! I should have said "sticky stuff"Stone Dude wrote:Glaxs is a urethane, not a resin.
That's better
