Brown Cohiba
Anyone ever had an issue with Brown Cohiba bleeding a greasy substance after install? We have tried acetone to get it off. Going to bring a piece back here and see what the heck it is, but it seems to just smear around. We sealed this stone with dry treat so whatever it is must be deep. ???
David G Stout
Belmarmi
cad@belmarmi.com
904-699-6752
Belmarmi
cad@belmarmi.com
904-699-6752
Re: Brown Cohiba
Can't say as I have ever heard of that and we have processed a ton of that stone.
Re: Brown Cohiba
brown Cohiba is so hard it don't need sealed , so what ever you sealed it with is probably still on the surface and could be what is causing this.
I doubt Acetone is strong enough to remove dry treat but could be wrong
Re: Brown Cohiba
did you buff the counter after sealing it? The excess needs to be removed. If it cured, acetone wont get it off, you'll need something like Stone Pro Stone Scrub to get it off easily. Don't seal this stone.
- Been thanked: 90 times
Re: Brown Cohiba
Just put more dry treat on to emulsify the residue and wipe off while wet.
Steven Nenzel
Rock-It Surfaces
947 Rancheros Dr
San Marcos, CA 92069
760-597-1800
steven@rockyourhome.com
www.rockyourhome.com
Rock-It Surfaces
947 Rancheros Dr
760-597-1800
Re: Brown Cohiba
We reproduced the problem here and it looks like the guys put tiger ager on the stone and didn't buff it off well enough.
I am going to try ager remover from tenax. We will see...
David G Stout
Belmarmi
cad@belmarmi.com
904-699-6752
Belmarmi
cad@belmarmi.com
904-699-6752
Re: Brown Cohiba
Just put more ager on to emulsify and wipe off. Never had a problem getting it off just by using more ager.
Steven Nenzel
Rock-It Surfaces
947 Rancheros Dr
760-597-1800
Rock-It Surfaces
947 Rancheros Dr
760-597-1800
Re: Brown Cohiba
x 2
