Silestone
- ageless
- Been thanked: 89 times
Re: Silestone
Oh I know it happens with all the engineered stones I just never heard of any in particular having more of a problem with it.
I think maybe they just got it stuck in there head.
Thanks for the reply
Re: Silestone
It doesn't happen any more/less frequently than any other brand, in my experiences.
Re: Silestone
blackdog.....can you fill in your signature line so that we know who we are talking to.
Link is in my signature.
Re: Silestone
I machine at a shop that produces around 15000 sq. ft. a week and have seen 2cm and 3cm silestone crack in many different ways. Even with relief cuts i have still had pieces break in multiple spot. I firmly believe that color and thickness have a lot to do with it. As far as different engineered brands cracking, im pretty sure all engineered stones are produced with the same concept in mind. In conclusion, all manufactured stones for the most part have broken on me without the proper relief cuts and with plunge cuts.
Allen Miller
"If you can't find your mistakes, the machine will find them for you."
www.surface-crafters.com
Re: Silestone
I thought the same thing.kevinp wrote:Wow! Is that a typo? 15,000 sf a week?
Re: Silestone
Not a typo its around 15000 give or take especially depending on the season
Allen Miller
Re: Silestone
When you say you had a customer that was sure of it, I guess you mean it was cracking once installed.....I have never found that to be the case with any e-stone. Its strong as hell and flexible to a point as well.
As far as on the saw, All brands do it, it seems the smaller the aggregate the worse it is. We used to put a shim in the cut the second the slab clears. It helps a little. Cut a bunch of viaterra way back when, and we used to jump when that sucker would pop......Horrible about stress cracking. The Breton guys told me that if they do not use the right formula or they do not allow adequate drying time it gets much worse.
On the fabcenter I had a special estone program that would run a 10mm deep step cut through at high speed on the whole slab, which helped also. Still they would crack, but at least usually it wasn't much past the over material.
Re: Silestone
wow 15000 sf.?
that is impressive, can someone do the math how many slabs per day and how many per hour, and how many saws do you need and what about installers, I must say you guys really kick butt
this is what you call a shop
Re: Silestone
We cut around 50 slabs a day, 2+ per hour per machine. We run 2 dual table northwood saw/water jets and 4 northwood routers.
Allen Miller
