LamLock Rocket Gel
LamLock® RocketGel™ is a fast-curing epoxy gel for stone that will harden and be tack-free in 25 minutes, depending on mass size. The appearance after curing will be transparent in thin layers. In layers which are about 1/8”, this glue will appear whitish and in thicker layers will be off-white.
This glue can easily be colored with pigments allowing you to make it any color you want. It will fully cure overnight, but shortly after it is tack-free it will be hard enough to scrape, grind or polish. May be used wherever a permanent bond is desired. Excellent for gluing mitered edges, fills and seams.
Mix 1:1 ratio
Mike Clark
DeFusco Industrial Supply
mikec@defusco.com
623 910-4577
mikec@defusco.com
623 910-4577
- Exodus Stone
Re: LamLock Rocket Gel
Send some this way. We will test it out.
Brett Catron
Exodus Stone
Hendersonville, TN
Exodus Stone
Hendersonville, TN
- Has thanked: 71 times
- Been thanked: 41 times
We will give it a try also.
DAVE WORRELL
Pres. Innovative Stone
(530) 362-0779
email: dave@innStone.com
website: http://www.InnStone.com
(530) 362-0779
If you need another tester, we can test it for you.
We just used it and liked it (a lot).
We are going to order more.
Thanks for the sample.
DAVE WORRELL
(530) 362-0779
(530) 362-0779
If this offer still stands I'd like to give it a go.
We received the sample a few months ago. We used it once. It gets too yellow.
My dad's guys like it a lot, but we only use it with color so far
It says add color for outdoors on the label.
Also; Mike is no longer with Dufusco.
I just talked to Paul who took care of us and gave us our SFA Discount (make sure to ask for it).
DAVE WORRELL
(530) 362-0779
(530) 362-0779
