If any one has a Midas helper out there I need your help, I just need a picture of the connections with the number wires
going to the controller, I have P-1,P-2, 10,11,12, this is suppose to connect to 1,2,5,6,11 , my guys puled out the controller before taking a picture or writhing it down,
thank you any help will be much appreciated
help with Midas Helper
- IMG_6464.JPG (440.29KiB)Viewed 338 times
Re: help with Midas Helper
give me your phone number , I have one in the back that's not hooked up , but may be able to take a picture and text it to you.
I sent pics , but mine are not labeled as your are .
post or PM you fax number , and I can copy the book and send it to you , the electrician should be able to
sort it out from that..
- Brian Briggs
- Has thanked: 44 times
- Been thanked: 81 times
Faxed through most of the book , at least what I thought you need to get it hooked back up , also trouble shooting details , etc... If you need additional info , let me know.
I do remember we either put in , or adjusted the speed control , as it was originally designed to a high speed , and it was too fast on polishing , but the machine is a PITA to try to top polish with anyway.
