Butcher block cutouts in granite?
Hello All, we installed an island with a U-shaped cutout for butcher block cutting board. we left a tolerance of 1/16" sides and back. needless to say it swelled and broke on the corner. What are your thoughts on the tolerance?
Thank you
Thank you
- Has thanked: 52 times
- Been thanked: 48 times
Re: Butcher block cutouts in granite?
well, obviously it should be larger than 1/16" in your case, but you already know that.
it may vary depending on the type of wood, and what direction the grain is running and how large the butcher block is.
we have never done it, but I probably would have done the same 1/16" and probably would have gotten the same result as you, so thanks for the heads up on that, it is one of those things that is obvious after the fact, but not so obvious before....
Luke Getz
Duca Stoneworks
Holland, Mi
616-886-1081
Duca Stoneworks
Holland, Mi
616-886-1081
Shouldn't swell more than 1/4" on all sides.
That sucks
That sucks
Too much to look decent, IMO.
- mikedean
- Has thanked: 131 times
notch the butcher block so it sits on top of the stone, set it in the hole. then you can leave 1" room if needed. dabs of silicone prevent block from moving.
Like a cooktop with a lip.
Mike Dean, SFA
The Top Shop Inc.
London, Ontario, Canada
519.455.9400 x230
The Top Shop Inc.
519.455.9400 x230
- Jamie Schiro
I like that idea. If I'm picturing it correctly it would act in the same way as a drop-in sink or cooktop. Outside edge overlapping the stone.mikedean wrote:notch the butcher block so it sits on top of the stone, set it in the hole. then you can leave 1" room if needed. dabs of silicone prevent block from moving.
Jamie Schiro
President
Jamie@ThompsonMarbleandGranite.com
Cell 419-544-1951
100 N. Bridge St.
Perrysville, OH 44864
Office 419-938-0002
Fax 419-938-6415
President
Cell 419-544-1951
100 N. Bridge St.
Office 419-938-0002
Fax 419-938-6415
Yep, that's the best way to do it.Jamie Schiro wrote:I like that idea. If I'm picturing it correctly it would act in the same way as a drop-in sink or cooktop. Outside edge overlapping the stone.mikedean wrote:notch the butcher block so it sits on top of the stone, set it in the hole. then you can leave 1" room if needed. dabs of silicone prevent block from moving.
- Has thanked: 9 times
- Been thanked: 31 times
Thanks for Posting this question, I probably would have not thought twice about just leaving 1/6" and that would just have been for wiggle room during install.
Jonathan De la Rosa
delarosajr1@gmail.com
If you leave enough gap and fill with silicone the silicone will bulge up when the wood expands. The customer does not like that, they'll call you over and over to redo caulk and when enough is enough they get upset... So I like the above idea a lot!Darryl Miller wrote:Yep, that's the best way to do it.Jamie Schiro wrote:I like that idea. If I'm picturing it correctly it would act in the same way as a drop-in sink or cooktop. Outside edge overlapping the stone.mikedean wrote:notch the butcher block so it sits on top of the stone, set it in the hole. then you can leave 1" room if needed. dabs of silicone prevent block from moving.
Hmm.... sounds like someone had a bad experience with this alreadykevinp wrote:If you leave enough gap and fill with silicone the silicone will bulge up when the wood expands. The customer does not like that, they'll call you over and over to redo caulk and when enough is enough they get upset... So I like the above idea a lot!
mbrennan:
Did you leave radii in the corners of the "U" or were they machined to 90 degrees? If you do this over, I'd round the corners of the cutting board to match the top.
What is the grain direction of the cutting board? Edge grain moves least: http://workshopcompanion.com/KnowHow/De ... vement.htm
we did not radius the corners, customer wanted 1/16th play with 90 degree corners
Owned a cabinet shop for years if I had to make a guess the wood used was maple. Maple will expand 7-9% laterally across the grain in a extreme situation. Meaning if you have a 15 x 15 hole for the block your board could expand 1/4" easily dependent on seasonal humidity and the customers use habits. I would follow the advice from other posters about rabbiting the cutting board down into the stone. I would cut a bevel on the outside edge of the board to give a thinner appearance to it. and I would oversize my cut out by 3/8" each way. I would make the cutting board a little thinner and screw a couple of boards against the stone and the bottom of the board that way it acts like a clamp, can be removed easily in the future or adjusted as need be.
Dustin Rupke
Countertop Solutions
Hays Ks
Hays Ks
