Hey there guys and gals, I have a job coming up where the customer is wanting a full mitre, inside corner included. we've done some pretty nifty work on our mitres with a lot of these new Calcuttas now available, But never having the chance to do a inside corner I'm just wondering if there are any tricks or tips floating around out there. We use a Park Industries Yukon II Thanks Guys!
Aaron
Mitre a 90 degree inside corner.
Scott Tresek
CNG Stone Products Ltd.
Regina, Saskatchewan, Canada
"The only limitation is your imagination"
Re: Mitre a 90 degree inside corner.
Cut as far as you can with the bridge saw, then flip it upside down and finish it by hand
I hate mitering inside corners without a seam. Although im a new fabricator, i notice others work everywhere I go. Almost every single time i see an inside corner that is mitered, its got a small crack right there smiling at me. After doing a few like that, i just always put a euro seam at the corners.
Also not that material warantees truley exist, but how do you comply with quartz guidelines doing inside corner miters? Most companies require a 3/8 radius at minimum.
One time I was at a ceasarstone distribution center and pointed out one of those inside corner cracks in their showroom. Too funny
Anthony Mroczka
A M Stoneworks
Kelseyville, CA
http://www.kvillestoneworks.com
Anthony@kvillestoneworks.com
A M Stoneworks
Kelseyville, CA
- Has thanked: 35 times
We normally integra glue a 150mm x 150mm 'L' shaped block on internal mitres. Whether it helps or not I'm not sure, but we've only had one crack. Although teenage kids sitting on tops helped with that.
Alex L
Workshop Manager for a small NZ based Benchtop company.
Where do you glue it?
Anthony Mroczka
A M Stoneworks
Kelseyville, CA
A M Stoneworks
Kelseyville, CA
I cut a 150mm x 1500mm block an 'L' shape with a radius in and glue behind the 2 edges on the underside. Then its all hidden with the substrate. I'll take a pic next week with one I have coming up.
Alex L
Hiding it in the substrate is what made it click. Now i get it
Anthony Mroczka
A M Stoneworks
Kelseyville, CA
A M Stoneworks
Kelseyville, CA
