Braking System for Rotating Table
- Scooter
Does anyone have some type of braking system they want to sale for an old rotating table the problem is it is loose so when you make long cuts it moves alittle.The table is a park industry's hydraulic rotating table with NO brakes.
Michael Baxter
Re: Braking System for Rotating Table
Very simple. Weld a big nut to the frame then weld a handle to the bolt, loosen when you want to rotate and tighten when you want to cut.
We did this on an old saw. Very simple and cheap
