CNC Saw... Check out Our New Beast
- Been thanked: 12 times
After some lengthy and thorough research I went with the Breton Optima Smart Cut 550. This machine is an animal... We Named her " La Bestia" The Beast in Italian... Gerry must have the easiest job in the world selling this machine. The program is very simple and we picked it up pretty quick. We have had many other machines over the years, multiple manual saws, water jet, edge machines, and a cnc saw, but Our new Beast is head and shoulders above all others. Basically a job with all miters that would take us most of a day if not longer, now is cut in an hour and it is precise!!! Our production in the shop has gone off the hook... I am very happy with the entire Breton Team starting with Gerry all the way thru the techs that have installed... After installation we had some questions and they either answered the phone or called us back right away.... I can't say enough good things about my overall experience... It's like having the best of both worlds... An Italian built machine for Stone with American service!!! This Beast is built to last and is extremely precise. The optima feature where it will pick up the pieces and move it out of the way so you can really nest pieces very tight on the slab. Then when you are done you can have the machine bring the pieces to the front of the table for easier pick up.The machine does not even blink when I move the pieces around. HEAVY DUTY IS AN UNDERSTATEMENT!!! You can run the saw fully automatic or if you want to run it manually you can use the joysticks and cut old school if you like....
- IMG_7101 2.jpg (157.82KiB)Viewed 695 times
Tony Sciarrino
TS Stone
TS Stone
Re: CNC Saw... Check out Our New Beast
I am so pleased so far. We cut an engineered slab up in 14 minutes...She has crazy speed and power I can’t tell you how much I recommend this beast!!! If any of you are on the fence I would go with the Breton Optima Smart cut
Tony Sciarrino
TS Stone
TS Stone
- Been thanked: 50 times
Tony,
Thanks for the kind words. The Job is not easy, but I suffer no delusions that being a fabricator is easy.
When the market is moving there are lots of players and a shortage of investors.
I know the investment was no small matter for you, and so it is an honor to us that you put your trust in us.
I'm so glad you're seeing the value in the mass. Keep destroying stone Tony, I'll be out for a demo soon!
Gerry Van Der Bas
gerry@turriniusa.com
(708) 315-4875
Proven Solutions in Dust Collection & Water Treatment
World Class Equipment and Accessories for the Stone Industry
(708) 315-4875
