I'm hoping Mike will chime in.
1. Can I use poly colors for this?
2. will this hold up to 120+ degrees in the sun?
Bonstone Last Patch question
Re: Bonstone Last Patch question
Cameron,
1. Our tints (polyester-based) can be used for all of our products: our Epoxies, our Polyesters, and our Last Patch products. I'm not sure about the compatibility of other's "polyester" tints--not sure what exactly is in them, so we can't be sure they'll work. Your best bet is to use our tints; or at least test the other's first before using them.
2. That temperature should not be a problem for Last Patch.
Call if you have any further questions: 800-425-2214.
Thanks!
Mike Beckmann
Bonstone Materials Corp.
www.bonstone.com
Thanks!
Mike Beckmann
www.bonstone.com
Just what I needed to know, thanks. I will be calling you as this could potentially turn into an extremely large repair job. Theres got to be at least 8-10K square feet of this stuff that needs surgery. 3 years old, direct sun exposure and it was all put together with poly.
