lines in polishing wheels
- chad201008
We just got new resin polishing wheels a week ago. Our CNC operator did something to them and now they have lines in them. Is there a way to dress the resin wheels? The last medal wheel is fine and has no grooves but the polishing wheels now do. Do I bring them in and dress them with the stone?
Looking back, fifty years from now, don't you want to say you had the guts to get in the car!!
Chad Wennberg
Duluth, MN
Chad Wennberg
Duluth, MN
Re: lines in polishing wheels
I don't think you can dress resin polishers. Some lines are to be expected. How bad are they?
Yes you can!
I won't tell you how though nor will Eric Pate probably. This is because you have to be very soft handed and your skill set on dressing diamonds needs to be extremely well. Not to mention you can easily and I mean easily destroy them if you don't really have the finesse and technique. I dress my fathers T'30's in the flats because they too have to be cleaned up after dressing and calibrating your diamonds. Also remember if you try this you will need to recalibrate a little on the resins.
Chad, are you an SFA member yet? You have been around a while now
He is. If you look under the username on the right it will say "SFA Member."
PM sent.
Ben Jensen
CNC Tool Geek
Fabtech Products/Tyrolit Vincent
320-333-1666
CNC Tool Geek
320-333-1666
There are 3 types of polishers. Just making sure we are talking about the same thing.
1. Resin or solid rubber.......
2. Strip rubber
3. Clay or composite....(BIGI, ADI)
We are talking about number one, not number 3 right????
2. Strip rubber
- chad201008
The lines are bad enough that you have to touch them up. Tue. night they were perfect. Then Wed. morning, after a few runs, they have lines that I have to fix. Inspecting the polishers, you can see the lines in the resin. The polishers are the rubbers with the clay like coating.
Chad Wennberg
Duluth, MN
Chad Wennberg
Duluth, MN
If you have a tight radius on the top you ran that could be the cause. Some of polish wheels are smaller in diameter than the metals so they will go into a radius a bit more. Like if you have a 4in diameter metal and try to run a 1in radius it will leave a little in the corner then the smaller polish wheel goes in and gets horizontal lines on them.Hope this helps
Mike Spencer,SFA
Blasius Inc
Vassar,MI
Blasius Inc
Vassar,MI
What profile is it. You have true "resin" wheels. The layer of resin is very thin and easy to screw up. Not sure how it happened. Maybe they were dialed in a little tight. Are the amps on the machine normal when running them????
- chad201008
The profile is a T30. The last metal is smooth but once the first polisher goes by, you can start feeling lines in the stone.
Chad Wennberg
Duluth, MN
Chad Wennberg
Duluth, MN
Polishers will develop lines independent of the metals. I know this because for quite awhile, I stopped the machine after the metals and hit it with a 400 to remove all lines and then run the polishers. Even with a steady diet of line free granite the polishers still eventually got lines after a while. Still the best way I have found to put out decent flat edges polishing on the machine.
- Randy Gallion
Run your metal bits then hand polish
No lines
No lines
RW Gallion inc.
12701 E. Sprague ave.
Spokane Valley, Wa. 99216
bus 509-927-7777
cell 509-688-7777
Iron sharpens iron So one man sharpens another Proverbs 27:17
Check us out on FaceBook
http://www.rwgallion.com
E-mail randygallion@usa.net
bus 509-927-7777
cell 509-688-7777
I am with randy. Since we discovered the 3 step pads you can run 400 pad, step 2 and 3 while also killing the bottom edge on most stones and be done. Polishing on the machine makes no sense. Only on trouble stones do we have to use the buff. Perfect polish.....Actually faster since we have to kill the bottom on these edges anyway.
Yes, They CAN be dressed. It is a practice I use in extreme emergencies only. I did it at the show I St. Louis. I've done it a many a times on customer tools that need them in order to save them some money and not have to buy new ones when there is still a lot of life left on them.
PM Sent to Chad
PM Sent to Chad
Ha now the kats out the bag. Your on the hook, the legalez wife told me so!
Don't forget to recali!
Well if your wife says that the statement provided still makes me liable then I removed the information and if one would like to know how to do it in extreme emergencies only, I will accommodate one on one.
