Currently we are using a trailer with single sided racks on each side of the trailer.
We are looking at something like a Sprinter or a cubevan. My dumb question is how do you mount the racks on the side going over the wheel wells. Should I just be thinking about building some kinda frame underneath so that my racks have clearance over the wheel wells.?
New Install vehicle
Mike Law
Kirkpatrick Stoneworks Ltd.
Fonthill, ON, Canada
- Mark Gamble
- Been thanked: 17 times
Re: New Install vehicle
If you raise the frame you will loose overall height restricting the size of pieces. I have been looking into the Nissan commercial vans. I like the leg room for it.
Barrie, Ontario, Canada
The wheel wells do do not stick out too far. I think you could use a built in A frame or do as we do, use a Weha frame and load every job by the frame,(it is much quicker).
How do you get the pieces out when you load the whole frame? Can you still use a pull out ramp?Dan R. wrote:The wheel wells do do not stick out too far. I think you could use a built in A frame or do as we do, use a Weha frame and load every job by the frame,(it is much quicker).
We walk on the frame and wheel well. we don't use a ramp (the deck is only 18" from the ground).
Mike, you are a member,go into the members area and click on "Sprinter Pics". I just posted them last week. It will show you how to fab the A frames over the wheel wells.
