Auto Fillet
Moderator:BrianStoiber
How do I turn off Auto Fillet in the software?
- BrianStoiber
Re: Auto Fillet
Auto Fillet is only active if you click on it in the side menu. If you are using it and want to end the process, there are two options in the bottom left; Open and Close.
Open will leave the drawing as is. Close will close the object by connecting the first measurement taken with the last measurement taken.
Let me know if you have any other questions or just give us a call (630-679-1300)
Brian Stoiber
Director of IT
Laser Products Industries
http://laserproductsus.com | 630-679-1300
Director of IT
Re: Auto Fillet
I'm trying to figure out why one of my template employees has been having a rash of bad templates recently. I know he had his laser set to auto fillet and I think he wasn't shooting enough points along a wall to be very accurate. I wanted to turn that feature off on his to eliminate that option for him so he has to shoot more points and get closer to the corner!
- BrianStoiber
Re: Auto Fillet
If he is using Auto Fillet, he should only be hitting two points per wall/cabinet face. If he is going to scribe the back wall, Auto Fillet should not be used on the walls.
Generally, the way to use Auto Fillet would be to at the beginning of the job, click Auto Fillet, measure two points on each cabinet face. Click Open to stop auto filleting and then continue to scribe the back wall.
Brian Stoiber
Director of IT
Director of IT
Re: Auto Fillet
Sounds good in theory!
I'll have a talk with him about what he's doing.
Thanks!
Thanks!
- BrianStoiber
Re: Auto Fillet
Let us know how it turns out. We are always here if you need help.
Brian Stoiber
Director of IT
Director of IT
