Keep your program updated.
Moderator:BrianStoiber
I have spent alot of time out on the road in the last 4 months since I took over the SE. I have been amazed how many of the shops that I have called on that their programs are behind on updates! You need to connect to internet at least once a month to keep up to date. We put out updates out almost every month. You should be on 505 by now or 495. you will see this when you 1st open the program. Any ideas or suggestions are welcome. We are all about helping you be more SUCCESSFUL!!!
Re: Keep your program updated.
Scott, so does that mean running on 206 is a bit behind the wagon?
Where on the site do I get updates and could you walk me through the steps to update ours?
Cheers
Cheers
Hand to Stone Custom Countertops
BC Canada
604-815-8662
BC Canada
604-815-8662
Dustin,
Just get on to the net with your computer that your using with the LT. Open up your Lt program. It will ask you to update and choose yes. That should should it. Be sure to check your tripod, the instructions are in an early post. Call me if you have any problems. Are you running a PDA unit? If you are what I just told you to do won't work.
Scott / 970-901-9459
