Why should I buy your science experiment instead of buying this?OTLVISE wrote:switched out the SAFETY Shoe in back with another open ended SHOE( I think that's what you mean). Replaced Pneumatic Swivel wheels(they suck) with these Casters and they work great(800 lb each). Adding smaller casters allows the use of 14 inch tires in front as Helpers and they make going up the stairs so easy as compared without. FYI you need 14 inch tires on stairs to avoid getting caught under stair lip..
Plenty of clearance with Patented Clamp head design... wide opening for Miters, tilt them out without lifting( I hope)
Added SAFETY Cane attachment so you can rest with piece being carried without lowering down much, thought that might help unloading truck and then placing in cart
Unit has replaceable axle so you can add more wheels if needed... these could also be used in the center
US Patent 8312598, 8573608, D719000
You apparently haven't ever used one of the Omni pro carts. We use one every dayOTLVISE wrote:you cant use that cart because it sits too high for large pieces in doorways and going up stairs etc
My cart sits more than 5 inches lower yet has larger wheels
OTLVISE wrote:that unit is 17 inches or so DAN, I suppose it would be fair though if you listed all of the carts you use versus my one lol
Most islands are 36", 42", or 48" tall. Not a problem.OTLVISE wrote:you cant use that cart because it sits too high for large pieces in doorways and going up stairs etc
