This time, we are looking for 10 fabricators, 5 of which who have used our 3-Step Wet System and 5 that have not. We need detailed feedback as to the overall performance of the System, as well as exactly how they stack up to competitors’ offerings. As always, good, bad or indifferent, all we ask for is honest feedback.
Our technical director, Eric Pate, has started testing with the following parameters, please read below before submitting your request:
Beginning Edge (showing the surface)
Pad #1 (showing transition)
Pad #2 followed by Pad #3
Pad #1 - 30 seconds on 13"
Moderate water
Maintained consistent muddy water until piece was done.
RPM on Barranca Polisher showed the knob as halfway
Pad #2 - 15 seconds on 13"
Moderate water
Polished until the pad started “biting” the material (grabbed).
RPM was a bit slower, roughly 1/3 of the way.
Pad #3 - 20 seconds on 13"
Moderate water
Polished until pad started “biting,” but stayed a little longer.
Same RPM as pad # 2
“By some standards I’ve seen at shops, we could have been done with this material by Pad #2. Regarding lighter colors, use Pad 1 & 2 then you are done. With Engineered Stones, it’s also a 2 Pad process. However, once you get up past the chocolate brown colors and some blacks, you may need to use our third pad as an optional buff.” –Eric Pate
If you are interested, please send an email to: Michael@continentaldia.com with the following information:
1) Name and company
2) Shipping address and phone number
3) Have you used Terminator 3-Step Wet Before?
4) Have you used any competitor 3-Step Wet Systems, and if so which?
