cleaning up files from lt55
Having trouble cleaning up files from lt55 .Some small lines are left over after fillet on corners and drawing off sets .Some are very small and do not show up untill i send into allendata Cad . I am new to this am i doing something wrong or is this just the way it is.
John Touhill
Touhill Custom Counters
Darby, Pa 19023
jtouhill@comcast.net
484-880-1684 Cell
office 610-583-1110
Darby, Pa 19023
484-880-1684 Cell
office 610-583-1110
Re: cleaning up files from lt55
You may be collecting too many points and creating too small line segments. For straight cabinet fronts, only two points are needed to define that as a line. If you are scribing walls, then every 6"-12" is typically good enough to follow the wall shape.
When adding fillets, choose the two elements closest to the corner you're filleting.
- pwukusick
- Been thanked: 12 times
After drawing your tops you can use the view/display contiguous breaks command to see any lines that are not closed shapes and fix or delete them prior to sending to allendatagraph.
Thanks for the tips but what concerned me most was that the line did not show in Lt 55 software fully expanded but did show up in allencad when we checked in there .We did not catch it in lt55 software and sent to cnc saw where it cut the line and ruined the piece .Did not think that should be possible to have line that does not show in Lt55 screen when fully expanded.
John Touhill
Darby, Pa 19023
484-880-1684 Cell
office 610-583-1110
Darby, Pa 19023
484-880-1684 Cell
office 610-583-1110
What software does your cnc saw use?
Do you not have the ability to do a simulation prior to sawing?
I personally would not trust the LT software for editing much more than vinyl templates.
When editing lt55 files, I would recommend to turn on measured points which will display 'x' for every point shot. Many times our templators will filet a corner but will filet the wrong segment. This error will be obvious with the display contiguous breaks as mentioned previously. If it is a software bug, I would recommend you talk to your lt55 rep. They are pretty good with fixing bugs within a few days.
+1 easy fix on the LTpwukusick wrote:After drawing your tops you can use the view/display contiguous breaks command to see any lines that are not closed shapes and fix or delete them prior to sending to allendatagraph.
We are using cuts from cad it came with our saw . I think it was something we did and not glich in LT software . I thought file was checked for open geometry with view/display contiguous breaks command but it might of been missed . We were use to just cutting Vynal and when there was a extra line no big deal but watching that blade come down in middle of island
has cured me of being sloppy with files.
John Touhill
Darby, Pa 19023
484-880-1684 Cell
office 610-583-1110
Darby, Pa 19023
484-880-1684 Cell
office 610-583-1110
I'm sure. It was a quick learning curve for us too!JOHN_T wrote:We are using cuts from cad it came with our saw . I think it was something we did and not glich in LT software . I thought file was checked for open geometry with view/display contiguous breaks command but it might of been missed . We were use to just cutting Vynal and when there was a extra line no big deal but watching that blade come down in middle of islandhas cured me of being sloppy with files.
Vinyl is cheap.
