angle grinders
4-1/2 angle grinder or 5" angle grinder for cutting off the end of a granite countertop in the field ?
Re: angle grinders
I believe if you are a digital shop, you shouldn't be needing a grinder on site
Maybe double check your template. Then cut to size
Joe Demick
Tile, Marble & Granite Specialists Inc
Jupiter, Fl
Jupiter, Fl
Re: angle grinders
If your asking for buying reasons, always go bigger.
Re: angle grinders
The makita var speed (12 amp) 4.5" & 5" grinder are the exact same grinder. Only difference is the blade guard diameter.
- Has thanked: 41 times
- Been thanked: 35 times
Re: angle grinders
This is true, I've used makita for years with great success. If you have an issue with one then call or email them and they will take care of you.Mark Smith wrote:The makita var speed (12 amp) 4.5" & 5" grinder are the exact same grinder. Only difference is the blade guard diameter.
Brian Andre
ANA Granite LLC
Flint MI
brian@anagranitellc.com
“We are all born ignorant, but one must work hard to remain stupid.” ― Benjamin Franklin
ANA Granite LLC
Flint MI
Re: angle grinders
5" blade whatever you choose. i use dewalt something orbanother
