CNC CW/CCW Tool Direction Question
- Has thanked: 15 times
The original training we got on operating our CNC called for clockwise travel on the outside of parts and CCW travel on inside cutouts.
We were wondering what the reason for this is.
Anyone know of a good reason for it?
thx
Mark in MN
thx
Mark in MN
Mark S.
Custom Stone Interiors
St. Cloud MN
St. Cloud MN
Re: CNC CW/CCW Tool Direction Question
I moved this question from the Members Lounge to the digital room so that we can get the tool guys input.
Good Question Mark.
The reason for those recommendations are this. When cutting with diamonds we really aren't cutting anything, as we are grinding with these tools. So Grinding creates pressure on the materials you are cutting as the diamonds are biting into the stone at any given feedrate. So if we look at this drawing as a better example below that comes from our basic cnc training manual.
We call Clockwise cutting, Climb cutting. This is to say that we are climbing the natural direction the tool wants to go based on the rotation of how the spindle is turning. In stone cnc machines we turn the spindle clockwise also. This method is best for grinding stone as it puts all the grinding pressure towards the finished part itself, preventing many types of blowouts and eliminating the need for most relief cuts, but not all, that usually have to be done with conventional cutting.
We call Counter Clockwise cutting Conventional cutting or going the opposite direction the tool wants to naturally climb. The only benefit here is for the tool, as the slurry is removed instantly away from the tool exiting the side instead of in climb cutting being compressed to the back and then exiting. This method usually requires backcut/relief cuts on all large radius corners to prevent blowouts when using fingerbits and large shaped profile.
Hope this helps
Hope this helps
So is there any reason to ever conventional cut? Who cares about slurry getting washed away quicker?
Tools life.
It won't affect it tremendously but with the data I have yes it will get you a 200 meter or more.
Sébastien Bergeron
Superviseur de la production
Shop supervisor
2280 Stevenage Dr.
Ottawa, Ontario
K1G 3W3
613-744-3005 ext. 232
sbergeron@mountaingranite.com
www.mountaingranite.com
Shop supervisor
2280 Stevenage Dr.
Ottawa, Ontario
K1G 3W3
Glad to know I am not the only one who tracked this trend of conventional vs climb cutting tool life. We saw a 5% increase in life over several sets this way. But 5% increase in life disappears real quickly when you blow a corner out on an Ogee set.
this definitely applies as well to hand fabbing - it is sometimes hard to get guys to understand that the direction the blade is going has a huge effect on chipping. some guys get it and some never do really get it
- Been thanked: 50 times
Gerry Van Der Bas
gerry@turriniusa.com
(708) 315-4875
Proven Solutions in Dust Collection & Water Treatment
World Class Equipment and Accessories for the Stone Industry
(708) 315-4875
So im still confused...climb or no climb?
Climb Cut = Better Cut
Conventional = Better Tool Life
You decide what's more important to you.
Climb Cut is better for the material. Less Blowout for those who do not utilize back cuts on materials like delicatus.
Hence the reason most cnc manufacturers teach you to climb cut, so you don't blame them for busted tops.
I'm not even doing it but best of all world.
Climb cut first diamond and then conventional for the rest.
Longer to program unless cam program can come with that preset in the tool.set.
I know alphacam might have something that comes close to.do it.
Sébastien Bergeron
Shop supervisor
2280 Stevenage Dr.
Ottawa, Ontario
K1G 3W3
Shop supervisor
2280 Stevenage Dr.
Ottawa, Ontario
K1G 3W3
Anyone taking notes here?
You all are freek'n learning me stuff.
Is this a great place or what?
- Clyde Kingry
- Has thanked: 31 times
Eric, what does this mean?
I usually 45 the corner on large outside radi, ( 3" to 6" ) clipping the corner, ... or clipping more than just once on a really big radius but what is backcut/relief cut process as it relates to this?... a breaker? or something else?
Clyde M. Kingry, SFA
Southside Granite Company
Dothan, Alabama
southsidegranite@gmail.com
(334) 797-5083
http://www.southsidegranite.com
Dothan, Alabama
(334) 797-5083
Relief cut is something cms brembana is doing quite well with easystone.
But it consists of entering the opposite side of what you will Fingerbit for 1 inch or less and then go back
To your normal machining and Fingerbit from the side you would do first.
We do this all day on euro seam so it doesn't chip on the final breakout it really consist of creating a weak spot exactly where you want it to break.
Sébastien Bergeron
Shop supervisor
2280 Stevenage Dr.
Ottawa, Ontario
K1G 3W3
Shop supervisor
2280 Stevenage Dr.
Ottawa, Ontario
K1G 3W3
Genius, I always just cut away from the face, which generally makes cutouts snap out into the waste direction, but I'll be employing this relief cut method from now on. Much more reliable and elegant way to do it.SbergeronMG wrote: ↑Wed Mar 29, 2017 5:19 pmWe do this all day on euro seam so it doesn't chip on the final breakout it really consist of creating a weak spot exactly where you want it to break.
I was taught to always try and make the bit be doing burnouts on the face you're cutting against, and it typically works out alright. I'll definitely be giving the climb method a go.
Ben Brecevic
Wet Polisher Slinger
Contemporary Granite and Marble
Beenleigh
Australia
Beenleigh
Australia
Make sure your radius drawing isn't explodedBen wrote: ↑Wed Apr 05, 2017 9:40 pmGenius, I always just cut away from the face, which generally makes cutouts snap out into the waste direction, but I'll be employing this relief cut method from now on. Much more reliable and elegant way to do it.SbergeronMG wrote: ↑Wed Mar 29, 2017 5:19 pmWe do this all day on euro seam so it doesn't chip on the final breakout it really consist of creating a weak spot exactly where you want it to break.
I've been having problems with curves, some turn out alright and others mill out a bit jaggedy, like the program is working in low resolution, could this be from milling curves conventional direction?
That will create segments the tool will follow
Lester Swick
908-418-5925 cell
LSwick1968@Gmail.com
TEAM BUBBA BOATER
908-418-5925 cell
TEAM BUBBA BOATER
- Been thanked: 36 times
So on my older hsd northwood, we got it 12 years ago or so and we were always told to reverse/left when picking directions. So it looks like we're climbing down, am I correct Eric?
Andrew Haldeman
Stone Crafters
Egg Harbor Twp NJ
Stonecrafters-nj.com
Stone Crafters
Egg Harbor Twp NJ
By exploded do you mean curves translated in cad as hundreds of tiny linked straight line segments? We had that problem with splines in ICam 3D, but we've found work arounds. Our machine does perfect bottom right and top left corners, and the bottom left and top right corners come out jagged sometimes. Usually if we're running edge profile tools like a set of pencil rounds or federation edges, the polishing wheels get rid of them mostly, but not always.CustomMarbleGranite wrote: ↑Thu Apr 06, 2017 5:52 amMake sure your radius drawing isn't exploded
Ben Brecevic
Beenleigh
Australia
Beenleigh
Australia
Mark,
When I spent some time with you on your original Alphacam training, I suggested a climb cut/grind over a conventional grind/cut for a couple different reasons. Blowout and spindle absorption were at the top of that list. If possible, I've found that moving in a clockwise direction on outside geometries and ccw inside sinks, will minimize spindle absorption . However, in certain applications, like seams, this is not always recommended. I would enjoy discussing this more with you during my next visit.
Troy G
Lackmond Stone Products.
Troy G
- Been thanked: 19 times
We have been running Cnc routers for about 6 years and have always ran outside edges CCW and all inside cut outs CW.
I'm confused as hell now.
Chris Evans
Rock Solid Granite and Tile, Inc.
Idaho Falls, ID
Chris@rocksolidgranite.net
Idaho Falls, ID
we had the DEKTON Representative in yesterday for a training session.
at first we were always advised to do Dekton and all sinks CW
We had a lot of blowouts on the lead out, yesterday we were told to cut DEKTON sinks CCW and it cut like a dream.
very quiet pulling 6-8 amps all the way through.
Sam Hanbury
Gmm Sawyer
CNC Programmer / Operator (intermac)
Precision Stone (UK)
Gmm Sawyer
