Hi everyone.
New here and fairly new to cnc in general.
I have a intermac master 30. Intermac came to give us training, set up tools etc..
We always noticed a little bump/ belly/ divit (what ever you wanna call it) where I tell the tools to start.
The minimum distance of attack was 15, after speaking with intermac engineers, they told me to increase this to 25.
Just done this and if anything, the bump has got worse.
Does anyone have any tips to getting rid of this problem? Not slating intermac, but feel I'm just running around in circles with them.
Thanks in advance.
Ben
Belly/ divit in bowl cut outs
- Been thanked: 41 times
Re: Belly/ divit in bowl cut outs
I get the same bump from my CNC router on sinks. More or less on all of em. Generally they are too small to care about. I put my finger bit enter/exit point inside the front rail of the countertop to lessen the chance of it being visible. I otherwise dont have a solution.
Colin O'Meara
Precision Countertops
Spooner WI
715 635 3470
"If I were ignorant I would be happy, but that is not a happiness I desire"-Voltaire
Spooner WI
715 635 3470
- Has thanked: 15 times
- Been thanked: 22 times
Same as Colin here. We enter and exit on the sides of sinks and the dip is minimal. Haven't had any complaint about them yet. You can barely feel it by hand.
Tim Zeng
Zeng Granite
Lincoln, Ne
402-429-8412 c.
tallzeng@gmail.com
Zeng Granite
Lincoln, Ne
402-429-8412 c.
tallzeng@gmail.com
- Has thanked: 32 times
- Been thanked: 25 times
Ben: You're gonna need to be spot on with your tooling measurements and speeds. A couple things that will help is to change your starting position for each tool or change your overlap setting on the tools in ICam. They are typically more noticeable when the tools wear if they are wearing uneven or not actually cutting the material away correctly.
As suggested on your other post, I would consider becoming a paid member to access the members lounge. There's a ton of knowledge to be learned about everything stone in there!
