Some of you on here may be aware of the new Keep-Nut™ anchors that we offer here at Chemical Concepts. But for those who aren't, these are high strength press-in, self-anchoring, threaded inserts that are rated up to 562 lbs per fastener. They can be used for undermount sinks, wall panels, facades, furniture, and more.
Installation is simple. It involves drilling a shallow, cylindrical hole into the surface to be mounted on, and driving the Keep-Nut into it with a rubber mallet. That's it. This anchoring system is especially suited for automated shops where all the holes can be plotted on CNC equipment. Once the holes are drilled, the fastener is installed in seconds which saves a lot of time and labor.
Advantages include:
● Compatibility with thin materials (including 2 cm- down to ⅜” depending on variety used)
● Shallow hole depth (<¼”) means less drilling in granite, less wear on bits, and less time on equipment
● Quick and easy installation
● Incredible strength (up to 562 lbs per fastener)
● Works in natural stone, “honeycomb” composite stone, quartz, solid surface, glass and a wide variety of high hardness materials.
Specs
SKU: CCH-KeepNut-2S-1/4
Min. Thickness: 8.5mm (11/32")
Thread Size:1/4"-20
Thread Length: 5.5 mm (7/32")
Bit Size: 11.8 mm (15/32")
Hole Depth: 6.5 mm (1/4")
Crown Number: 2
Avg. Press-in Force: 90 lbs.
Avg. Pull-out Strength: 562 lbs.
Interested?
We’re offering 10% off your first Keep-Nut™ starter kit which includes:
• 4 - Keep Nut 1/4"
• 4 - Allen Posts 1/4" -20 x 1-1/4"
• 4 - Sink Clips
• 4 - 1/4"-20 wing nuts
• 4- Star-washers
• 1- 11.8 mm (recommended size) 1/2 GAS CNC Drill Bit
• 1- "Go/No Go" Hole measurement gauge tool
• 1- Setting Tool
Starting price: $82.50 $68.67
This kit includes all the one-time-purchase accessories you would need to get you up and running with this system plus enough anchors to do one sink. If the system is not for you, you can return the parts for a full refund. We are looking to get more feedback on this product so we are happy to extend this offer to our partners in the SFA so they can give it a try and let us know what they think.
**ALSO** We'll be at the TISE (The International Surface Event) in Las Vegas on January 20-22, 2016!!!
We will be located at BOOTH 3563 - Stop by for a demonstration! Hope to see you there!
Check out the video from our YouTube Channel:
https://www.youtube.com/watch?v=mHbWHG-vUd0
For more information, check out our online store! http://www.chemical-concepts.com/keep-nut-1.html
