Aerowelding and Fab llc is Moving and All Heavy Fabrication Equipment, Tables, Welders and tooling must go asap!!
Location is 2771 E 9th st Suite C Newberg OR 97132
Give me a call if you want to schedule to come by and purchase. 503-819-1221 Julie / Troy
There is more Heavy equipment that is not listed. Please come and see it for yourself or contact me for more info and pictures: julia@aeroweldingandfab.com
Everything works great and has been well maintained.
Here is an add with some pictures: https://www.classifiedads.com/tools/ddf6bfbfbx4z
https://www.classifiedads.com/farm_equi ... x3bxjnrx4z
Big Items:
HTC Hydraulic Squaring Shear in Perfect working order, Shears 12' x 28ga - 1/2" thick, Comes with Owner's Manual, In operation, Come see it shear live. And comes with extra parts $19500 https://www.classifiedads.com/farm_equi ... c6nmqcjx4z
https://www.classifiedads.com/tools/fxbx5qybsx4z
40” Lathe & Tooling $5,995.00 https://www.classifiedads.com/farm_equi ... w6r2mccx4z
8,000 LBS FORK LIFT $7,500.00 https://www.classifiedads.com/farm_equi ... f4npyf8x4z
2 band Saws for $200.00
8’ BIRMINGHAM BOX & PAN BRAKE $5,500.00 https://www.classifiedads.com/farm_equi ... 4bntgj4x4z
Corner notcher $375.00
New!! Plasma Cutter Thermal Dynamics $2,500.00 https://www.classifiedads.com/tools/xc2xcxcxnx4z
press $80.00
Ridged pipe threader with extra stainless dies $2,000.00
Sharp Milling Machine & Tooling $5,995.00 https://www.classifiedads.com/farm_equi ... b70kpr7x4z
shrinker / stretcher $100.00 https://www.classifiedads.com/tools/d52zhv74vx4z
skill saw $75.00
torch set (large) bottles and cart $300.00
New!! Track Torch with Track $500.00
Ford Truck with utility box bed $1500
New Thermal Dynamics Plasma Cutting System 102 $2100
Fixatures and Furniture:
2 Heavy Duty ½” steel Tables $500.00 each https://www.classifiedads.com/tools/dw2b78w3bx4z
3 black Filing Cabinets $20 per
1 Heavy Duty Steel sheet metal Rack $500.00
1 Heavy Duty Custom Steel I-beam Rack for tubing, flat bar & pipe $1,200.00
2 Nice Black Super comfy Office Chairs $50.00 each
2 pipe stands (positioning) $100.00 each
10 pipe stands $75.00 each https://www.classifiedads.com/tools/d56123tf9x4z
1 Large heavy duty Safe $2,700.00
1 welders Personal Steel Table, with rod holders $150.00
1 Stainless Steel custom made blue print reading Office Table $275.00
1 White wooden working desk $250.00
Brown wooden Desk $50.00
Welders:
All welding rod and hot box $100.00
MAX STAR 150 STH W/X CASE $1,000.00
Like New!! MILLER DYNASTY 200 contactors package $2,500.00
Spool Gun with lead and extra spools $500.00
Like New!! 2 Spot Welders $60.00 total
Stainless Cleaner with 40 Gallons of acid cleaner $2,100.00
Suitcase welder $500.00
New !! Tweco Fabricator 211i 3-IN-1, lots of welder accessories and Replacement Parts, welding wire and rod $1,900.00
Small tools and kits:
High quality Belt sander and extra belts $900.00 (Custom ordered for $3500) for sanitary applications
Belt table sander and extra belts $35.00
Hardware boxes $10 per
Bench grinder $25.00
Grinders $35.00
Die pen and magna flux kit $125.00
Electric motor with gear reduction $200.00 per set
Flaring Tools and accessories $175.00
Hand Pipe Threading Cutting tool $75.00 https://www.classifiedads.com/tools/d555v75q2x4z
Painting supplies $150.00 for everything that is on the cart
New !! Micrometers set $475.00
Comealongs $25.00 each
Large objects:
compressor $500.00
Job box $100.00
10 large full bottles $175.00 each
2 short ladder $50.00 each
2 tall ladder $75.00 each
2 totes $50.00 each
1 Cobalt Tool Box Upper & Lower $500.00
10 steel hardware storage boxes $10.00 each
1 fiberglass hard hat $25.00
2 stainless steel 51.49 gallon tanks 10ga with legs $500.00 each
Moving Sale Fabrication Shop Heavy Equipment, Tools, Tables & Steel Racks, Everything must go!!
- 240117001_roy4pA.png (785.83KiB)Viewed 482 times
- 240117001_pI-zIw.png (629.16KiB)Viewed 482 times
- 240117001_DO115Q.png (537.32KiB)Viewed 482 times
- 240117001_Al7JgA.png (592.43KiB)Viewed 482 times
- 240117001_8nlr4Q.png (604.06KiB)Viewed 482 times
Re: Moving Sale Fabrication Shop Heavy Equipment, Tools, Tables & Steel Racks, Everything must go!!
I wonder if the stretcher is set up for 3 cm stone?
Could be a good buy
Granite stretcher a must have in the stone business
Shrinker Strecher picture : https://www.classifiedads.com/tools/d52zhv74vx4z
Im sure its only for steel and aluminum
Is any of this stuff for stone?
Anthony Mroczka
A M Stoneworks
Kelseyville, CA
http://www.kvillestoneworks.com
Anthony@kvillestoneworks.com
A M Stoneworks
Kelseyville, CA
Dibs on the stone stretcher.
