Perfect for the small shop beginner. Get started for fraction of the cost. I started with this, a worm drive saw and some homemade guides. You can set slabs with your lift and lower it by yourself. While we recommend using 2 people, especially when lowering Granite slabs. It's also works well as a fabrication table, if you're limited on space and Fab tables. Simple and safe to use. The table is in good working condition. We've been fortunate enough to be able upgrade to a bridge saw with a tilt table and no longer have room for it.
We will load it, Purchaser is responsible for all shipping cost.
Asking $800.00 OBO
Adam Dozier
DanChar Surfacing Systems
2949 Wilson-Cambria Rd
Wilson NY 14172
716-983-0845
dancharsolidsurfaces@yahoo.com
Manual Tilt Slab Cutting Table - SOLD
Re: Manual Tilt Slab Cutting Table
Hey Adam congrats on the bridge saw upgrade! I bet you will get a big grin if you start adding up how much stone you cut on that table
Always thought that table was a great investment for you. I am sure someone will snatched it up!
Thanks JD! Stop by and check it out sometime, it's incredible how much more efficient we are already. I plan on popping in to see you soon.
DANCHAR wrote: ↑Sun May 07, 2017 1:10 pmPerfect for the small shop beginner. Get started for fraction of the cost. I started with this, a worm drive saw and some homemade guides. You can set slabs with your lift and lower it by yourself. While we recommend using 2 people, especially when lowering Granite slabs. It's also works well as a fabrication table, if you're limited on space and Fab tables. Simple and safe to use. The table is in good working condition. We've been fortunate enough to be able upgrade to a bridge saw with a tilt table and no longer have room for it.
Asking $800.00 OBO
Adam Dozier
Wilson NY 14172
716-983-0845
I know this was last year but do you still have this? Call me if so.
Nick - 614-357-7524
Bountavee Nick Souvannavong
Miracle Stoneworks LLC
1661 Lockbourne Road
Columbus, Ohio
614-357-7524
Nicksgraninst@gmail.com
Miraclestoneworks17@gmail.com
Columbus, Ohio
614-357-7524
I changed the title of the thread for you.
