We bought this machine in July of 2017 and its been great for profile edges and sink cut-outs.
We got great use out of this table but with a higher work load we are going to a bigger machine.
Everything on this machine is perfect and has been very well maintained, it comes with a saw attachment
and vaccum system.
Asking $23,000 OBO
Buyer responsible for cost of shipping
PM me If you are interested or have any questions
Cut out holes for sinks
Edge profiling and polishing
Shape and polish internal profiles (sink holes)
Drill faucet holes
Create grooves and slots on edges
Cut and polish vertical (90°) edges
Cut and polish miter (45°) edges
Simple to install and easy to use
Operating head driven by a powerful and reliable electrospindle
Spindle equipped with internal and external water lubrication systems
Internal lubrication system for CNC tooling and GTOOLS with diameter of 22.2 mm (for manual machines)
External lubrication system is for profiling tooling
Change tooling quickly and easily with the quick-change tooling holder
Mount a cutting disc (max diameter of 200 mm) on the spindle (X-axis)
Make vertical cuts (90°), miter cuts (45°), and edge grooves
Adjust spindle rpm with control panel (24 V AC low tension controls)
Real time display on digital tachometer
Easily make manual micrometric adjustments on Y and Z axis (for extremely accurate profiling)
Work surface operating area: 118” x 43” (300 x 110 cm)
Maximum length for cutting disc (90° and 45°): 118” (300 cm)
Maximum length for edge polishing (90° and 45°): 118” (300 cm)
Maximum slab thickness for disc cutting: 4 cm
Maximum slab thickness for profiling and polishing: 6 cm (on vacuum cups)
Overall dimensions (with the template-holder raised): 138” x 93” x 65” (350 x 236 x 165 cm)
Weight: 1499 lbs (680 kg)
Electrospindle: 2.2 kW with internal water lubrication
Manual lifting and locking the operating head
Automatic internal and external tool lubrication
Supply tension: 230V 50/60 Hz single-phase
Water pressure: min. 2 bar
Pneumatic pressure: 3 bar
1 connection Ø 22.2
Stainless steel spindle
3 Spindle positions: Vertical (for profiling and slot cutting), 45° inclination (for disc cutting and bevel polishing), and horizontal (for disc cutting and edge polishing)
Spindle connection: ½” gas F
Spindle rotation speed: from 1500 to 12500 rpm (controlled by vector drive)
Vertical movement operated by a hand crank
Vertical stroke: 10 cm
Suction device for cornices (optional)
No. 8 suction cups (optional)
