2007 Marmo Meccanica LCT 522.
Excellent condition. Purchased this machine in like-new condition with 700 hours on it. It is an absolute workhorse. It will produce a perfect Flat, ½ Bullnose, Full Bullnose, Bevel, Crescent edge at about 1’ per minute from saw cut edge. I trained all of my guys to use this machine with no problem.
$35,500.00
2003? Crown Construction Bridge Saw
Good condition. Purchased this machine from Dan R. about 2 years ago. It has served us very well. 15 HP motor and turning table. Cuts straight and moves quickly through all materials. I have been using a 14” Diarex Machete blade on it which has been a good blade. We have been fabbing between 4-6 kitchens on it per week with no issues. We added a new wireless control with 2 pendants about 8 months ago. All parts are available from Grainger or other industrial supply company.
$7,600.00
StonePro Wire Sink Cutout Saw
Good condition. Purchased this machine from Stone Pro in like-new condition. Will cut out a 50/50 sink in about 20 minutes. Main consumable is the diamond wire from Diamond Boart. About $600 will get you around 100 sink cutouts. Great machine.
$5,900.00
2006? Atlas Copco 15hp Screw Compressor with integrated dryer
Excellent condition. Got this compressor from Eric R. about a year ago who did a great job maintaining it and keeping it clean. We did a good job keeping it clean (not as good as Eric) but we just did the major service on the machine about a month ago. New belts, Air Filter, Oil Filter and Oil change around $600.
$5,500.00
Laser Products LT-55
PDA Version. In very good shape. Still have all original parts and a lot of targets. Laser products is 5 min from my shop so if you want to have them do a service or upgrade to LT55 XL before it ships to you, I can have that done easily.
$4500.00
Graphtech FC-7000 - 54” Model
Super accurate plotter. Great for making templates. Can plot 2 counter templates side by side to speed things up. Takes vinyl up to 54”. I have plotted up to 120” with absolutely no tracking issues. Paid around $5,500.00
$3,500.00
26’ Jib Crane SOLD
This is a great jib crane that services our entire 60’ x 40’ Shop. We take pieces right from bridge saw and load them on Marmo at other side of shop. Acquired from Dan Toy. We built the concrete pad ourselves and we have the drawings from the crane company in IL. You will be able to get a new mounting plate and j bolts from the manufacturer. ½ Ton capacity. It can lift full slab of absolute black with no sweat. 15’ I think from the floor to the bottom of crane beam.
$ 2,100.00
½ Ton Coffing electric hoist. SOLD
Good Shape. We just replaced the cable and rewired the control and added some metal mesh protectant on the cable so when your guys pull the jib with the cable (which they will) it wont pull the wires apart.
$800.00
Manzelli 4 Pad Powertilt Liftter SOLD
Very good condition. This is the big one. Purchased new about 1.5 years ago from Granquartz. Paid around $4200.
$2,950.00
2006 Harris Accuglide Rail Saw. Good Condition. This was the saw that built our company for the first 2 years. We were able to fab 3-4 kitchens per week with this guy. It is lightweight which is good but you gotta let the blade do the work and normally step cut. I think we bought it for around 4k.
$1,500.00
2007 Barranca Rail Saw.
Like New Condition. We used this saw around 4 times right before we bought our bridge saw. It has been sitting on the shelf since. Paid $1,700.
$ 900.00
Gorilla Grips (2 pairs) SOLD
Both in good shape. My installer hardly ever used em (his seams did look good though). If I remember correctly, the cases are a little cracked but unit itself is in good shape.
$395 Each
Sink Savers (2 – 6’ Rails) SOLD
Good shape. Used a couple times a week by installers.
$185 Each.
A Frames – Up to 11,000 lb (25 Pairs) SOLD
Great condition. $100 ea
Aardwolf 8’ Transport Rack SOLD
I bought this rack a couple years ago thinking we would load install trucks with finished jobs. Never happened as installer had a custom built a-frame with toolbox on his truck. Very good shape. Granquartz’s site is down at the moment but Ill post a link later. Paid about $850.
$625
Bundle Racks (2) SOLD
Very sturdy bundle racks. I think they are 10’ long. 6’ upright poles.
$400 Each
Updated above! Thanks and keep em coming!
