I need to move these machines to make space for new equipment.
International Machine Corp. Stationary Bridge Saw
Moveable table top, 220V Motor Table is 20ft wide X 44” deep with bridge arm, 7 feet high, total depth of 9ft
$4000.00
2004 CMPI Mini 60 Inline Polishing Machine
Multi Head Lineal Edge Polisher for Granite and Glass, 1 calibrating head, 6 polishing heads, 1 top bevel, 1 bottom bevel
6’ D, 18’L, 8’ H
Currently under power
$19,000.00
2004 Sawing Systems 5RP Radial Arm Work Center
Cutting out bowl holes, Profiling bowl holes, Profiling external edges, Surface stock removal (gauging), Polishing surfaces, Drilling faucet holes, Drain boards.
Standard Specifications
‐5HP Baldor Inverter Motor‐Variable speed pulley system (200‐10,400RPM)‐4" spindle raise and lower‐10" powered raise & lower in the rear post‐6'‐10" maximum distance from back post to spindle‐360 degree rotation‐1/2 inch gas thread tool connection‐230 volt, 3 phase standard
Not under power, taken out of service in operating condition.
$9,000.00
Pm for pictures.
Richard Cantarilho
Fernando’s Marble Shop, Inc.
15910 Indianola Drive
Rockville, MD 20855
Ph. 301-670-2794
Fax 301-840-1725
richard@fernandosmarbleshop.com
http://www.fernandosmarbleshop.com
surplus equipment for sale
Richard Cantarilho
Fernando's Marble Shop, Inc.
Rockville, MD 20855
Rockville, MD 20855
