Park Destiny
I have a destiny cnc ,i started getting a spindal drive fault alarm,call park informed me to change spindal control module.After changing still getting the lite .spindal runs fine until it touches stone.then it faults out again.
MICHAEL CHEANEY SFA MEMBER
Re: Park Destiny
Park techs ave very knowledgable. I would call them back.
A few ideas:
Ask them to reload (reprogram) the plc and to check that the spindle power parameters are set correctly.
Check the power cable between the drive module and spindle. Also check that the cable inside the connector on the spindle side is not frayed or has loose wires.
A few ideas:
