So I set it up, snapped a pic with the overhead cam, programmed an e-box & moved the lead-in to the center of the cutout. Measured the thickness of the tile. Told the Fusion the size & started it up.
...it split the tile in half immediately.
Like I said, it's a wavy tile, so it's not flat on either side. Any tips or recommendations for trying to cut these with the jet successfully? I didn't do anything special. I literally just set the tile on the rubber slats. Would there be anything I could set under it that might help? Or does it sound like these tiles have too much tension & just wont survive that pierce cut?
