Is this installed right??
Our kitchen was flooded, causing cabinet damage. The original quartz counter top broke when removed, so we had new granite counter tops installed. I've attached pictures of our bar. Does this install look right to you? This wasn't how our bar used to look and it seems odd to have the plywood under the granite. Our contractor says this is normal, but I'm skeptical. I would appreciate your feedback. Thanks.
Re: Is this installed right??
I would say that's not normal. That might have been a part of your old counter top but with your new configuration that fiber board serves no apparent purpose. From what is visible in these pictures, that wood should be removed.
Camden Creek
Countertops of Memphis
Thanks, Camden. What do you mean by my old configuration? I haven't changed the bar in any way. Why would the plywood be okay in one situation and not another? Thanks for clarifying.
I'm guessing that your old counter was a 2cm material with a laminated edge that would hide the fibre board.
Your new counter is 3cm material that does not require the built up edge.
The fibre board would be needed to "build up" your old counter so that you can open your cabinet doors.
The 3cm material should be able to sit directly on the cabinets.
Reay Hunter
The Old Barn Granite
173480 Mulock Road
RR #3
Hanover ON
N4N 3B9
www.theoldbarngranite.ca
173480 Mulock Road
RR #3
Hanover ON
N4N 3B9
Thanks, The Old Barn. My concern is with my bar where there are no cabinets under it. I understand now the difference between my old counter top design needing and hiding the fiber board and our current design. So what I think you're saying is with my current design, the fiber board needs to be removed and the granite will sit right on top of the stud wall, right? What's the worry with keeping the fiber board under it except for it looks bad? Is there concern that it'll warp over time and crack the stone? I need to know if I should be requesting it be removed and fixed. Thank you!
"Need to be removed".....not necessarily. It may have been left in there to accommodate issues in the rest of the kitchen. If you remove it there, do you need to remove it at the sink, the range, etc. Especially look at where the dishwasher is at. If you remove it, do you drop below 34" for the opening height. We use particle board on projects to raise the "top" of the cabinets because there are times cheap flooring companies come in and lay new tile without removing the existing floor...thus making the finished height of the cabinets less than the standard 34 1/2".leitelbach wrote: ↑Fri Jan 31, 2020 4:01 pmSo what I think you're saying is with my current design, the fiber board needs to be removed and the granite will sit right on top of the stud wall, right?
What I would do if it were my house.....apply something to seal the edge of the particle board so it is paintable. I'm not at the shop, so i can't tell you exactly what the product is...ask the person in the paint department at the box store and they'll know what to recommend. I would then paint the edge and if needed the bottom so it looks finished...either black or the call color. Where there is a slight gap between the stone and the PB, I would put a small dab of silicone and prop the PB up until it grabs and closes the gap.
I don't think it needs to come out based on what I'm seeing. A piece of shoe molding or 1/4 round would make it disappear.
Thanks for all the suggestions. If the particle board was removed, it wouldn't affect any other part of the kitchen such as the dishwasher or the range. It's under the bar... on the other side of the wall where the sink and dishwasher are. You've given me good suggestions on how to "hide" it, since I think it looks unsightly, and it may come to that. But my last question is... I was told that in the future, when the particle board warps, it'll crack the stone. Of if we put anything heavy on top in the middle of the bar, the stone could crack. I was told, to do it right, the granite should be resting on the stud wall. But your suggestions don't seem to imply these would be true concerns. Any thoughts on the possibility of the stone cracking if the particle board isn't removed? Thanks so much!
The particle board can swell if it gets exposed to moisture from a leaky faucet/sink/etc. (a separate problem). It may also swell over the dishwasher from steam if the raw wood isn't sealed (see Guy's recommendation above.) Even if it swells from moisture, it is difficult to predict whether it exert enough force to damage the stone.leitelbach wrote: ↑Sat Feb 01, 2020 2:49 pmBut my last question is... I was told that in the future, when the particle board warps, it'll crack the stone. Of if we put anything heavy on top in the middle of the bar, the stone could crack.
Depending on how the wood sub-top is bonded to the stone, it may add a bit of additional strength, or very little (if spot bonded). The stone itself and how the sub-top is adhered will have more to do with the ability to bear weight than makeup of the wood.
That piece doesn't look that big. Is is a bar top? Do you have a photo of the top side of it?
A piece of trim could make it look better, but it also might be best to remove the particle board and then reinstall the top right on the wall. How wide is the wall under the stone? How big is the overhang? Will people be leaning their weight on the stone? If so, a better sub support would be better, like steel brackets.
"Is this installed right?"
Absolutely not. Shameful. When enough customers make this hack do his work over, he'll get the message and stop. Time for a hillbilly to pay some tuition at the school of hard knocks.
