good dry pads
My husband and I have been doing granite for some time now. Having a hard time finding a good quality dry polishing pad. Have used ones on ebay - some cheap and some expensive - none seem to last long or that will work everyday. The orginal set we started with were regent pads - but my bro-in-law said they had costed him $400 for the set - at 1st we thought he was kidding but we have worn those out and bought many to replace - none of them compare. Cant really afford a set of dry pads for $400 but even if we could cant seem to find that exact style. Anybody have any suggestions? Thanks
A to Z Kitchens
Nate & Jacky Kreutter
Warsaw, NY 14569
Warsaw, NY 14569
Re: good dry pads
If you polish alot, you need to go with wet pads, they last longer and you get a much better polish !!
Re: good dry pads
I know that the dry pads are for after installation - thats what we tend to use them for - its just the ones we have bought in the past just dont perform like the ones we were using in the beginning. Dont tend to polish they tend to smear and glaze up. We are running at about 1800 rpm's. We do use the wet pads in the shop for the production work. The dry ones we use just for installing, touch ups, and sometimes field fabricating (the set of regent swe got several years ago, saw us through over 300 installs - fast good polishes - the newer ones glaze up, discolor countertops, wont shine, sometimes tear apart when they are new. We just need a set of really really good dry pads -
A to Z Kitchens
Warsaw, NY 14569
Warsaw, NY 14569
Re: good dry pads
cjbritt1....
First, please fill in your profile/signature so we all know who we are talking to.
http://forum.stonefabricatorsalliance.c ... =signature
Dry pads in the field...my guys still tend to use a little bit of water on them when they touch up. They just wipe the material and the pad with a wet paper towel. The ones that they seem to like the best are the vipers from Braxton Bragg. (I believe those are the ones they are using now) They are a bit more expensive, but in the field finishing an install, it's worth it.
Re: good dry pads
Never really found a dry pad I liked. We do as Guy has said also, but use wet pads at the end with a little water. Low rpm.
You might try Phoenix Diamond tools. I think that's where I got my last set. They have held up great.
- t-mobile
Re: good dry pads
Any dry pad that has a honeycomb pattern will polish great. I have found these to be the best. I also agree with the others. A spray bottle and wet pads will yeild better results than any dry pad.
Tony Neylon
Delta Stone LLC
4664 Halls Mill Road
Mobile, Alabama 36693
(251) 660-1818
Delta1stone@yahoo.com
Delta Stone LLC
(251) 660-1818
Re: good dry pads
Dont laugh but you can use wet pads and use Vaseline to keep them lubed while polishing in stead of water just dont use to much or you will have a big mess. Works great on es
Re: good dry pads
Sorry, could not help it
- Troy Burnette
Re: good dry pads
- Antonio Almonte
Re: good dry pads
Still funny!
Antonio Almonte, SFA
River City Stone Inc.
Winnipeg, Manitoba, Canada
http://www.rivercitystone.ca
Re: good dry pads
I wanna know who pulled the vasaline out that first time you guys tried that
- Dan Dauchess
- Been thanked: 10 times
Re: good dry pads
dimmer switches..... vaseline.....
what next?
what next?
Dan Dauchess
Signature Stone
256 Industrial Blvd.
Toano, VA 23168
http://www.signature-stone.com/
ddauchess@signature-stone.com
Signature Stone
Toano, VA 23168
Re: good dry pads
It would probably be better to use than vaseline since it is water based. You don't have to worry about getting an oil stain on the top that way.Tynan wrote:Leave it to Ash to bring up the K-Y Jelly !!
Re: good dry pads
I am going to go out on a limb here and say water. I don't want to be slinging vaseline around a house. And the ky jelly would just make it weird.
Re: good dry pads
It was all started because of es and pad burns we need to much water to make it look right in someones house and didn't want to make a 50 mile drive back to the shop so we improvised to get the proper lubrication
- db*toolgirl
- Has thanked: 17 times
Re: good dry pads
We (DIAMANT BOART) have a couple different styles of dry pads our customers have had excellent results withcjbritt1 wrote:My husband and I have been doing granite for some time now. Having a hard time finding a good quality dry polishing pad. Have used ones on ebay - some cheap and some expensive - none seem to last long or that will work everyday. The orginal set we started with were regent pads - but my bro-in-law said they had costed him $400 for the set - at 1st we thought he was kidding but we have worn those out and bought many to replace - none of them compare. Cant really afford a set of dry pads for $400 but even if we could cant seem to find that exact style. Anybody have any suggestions? Thanks
Note: For faster results when using dry, pads should be opened "wet". When used on marble, the optimum RPM range is 2,000 to 2,500. For granite - 2,000 RPM dry- 4,000 RPM wet.
Annie Cline
Fabrication Sales Manager
913.219.5087 - cell
563.419.4722 - cell 2
annie.cline@husqvarnagroup.com
913.219.5087 - cell
Re: good dry pads
Here at DeFusco's we carry a few different brands of dry pads, but if you want a fast working dry pad with good life that will leave a finish every bit as well as a wet pad we recommend the slayer dry pads. They are inexpensive and high quality. You can see them here:
http://www.defusco.com/4-Slayer-Premium ... l-Set-3188
and no vaseline required
Mark
Mark
www.defusco.com
Stone tools for the professional with the best service & technical support in the industry!
