I found this link to making your own tri pod feet
http://www.cloudynights.com/item.php?item_id=2759
Tri Pod Feet
- Clyde Kingry
- Has thanked: 31 times
Re: Tri Pod Feet
all the plastic parts around the legs of my Berger tripod keep cracking and breaking. Is there anywhere to purchase those parts?
Clyde M. Kingry, SFA
Southside Granite Company
Dothan, Alabama
southsidegranite@gmail.com
(334) 797-5083
http://www.southsidegranite.com
SFA Members Map
Dothan, Alabama
(334) 797-5083
SFA Members Map
Re: Tri Pod Feet
Clyde,
If your Berger accepts threaded feet, you can do as Ahjort suggested and buy some from Grainger.
Search for "vibration isolator" bases. They have threaded post with rubber base "feet".
- Clyde Kingry
Re: Tri Pod Feet
Im looking for the orange plastic pieces that hold the each leg assembly together with the plastic spacer between them. Its the only thing on mine that was plastic. I presently have them duct taped together which is dine until you need to adjust the height. Its also the only replacement part i havent been able to find
Dothan, Alabama
(334) 797-5083
SFA Members Map
Dothan, Alabama
(334) 797-5083
SFA Members Map
