Quartz
I opened my shop in 2004, after being a salesman for another company for a year. I
A builder says" can you do this " I say " do I have your business " he says, you already do" . So I've now I've been in business for nine years, and I've learned more than I ever thought I could about stone.
I've always steered clients back towards 3cm granite, I just didn't want to work with a man made material such as quartz.
Now I have started, we have no polish machines, just a rail saw, and router. People ask me about my machinery, that's my helper and he is awesome.
My problem, 7 slabs of quartz with a miter edge. A designer and builder I'm exited to work with. We usually use tape for the miter edge, but I want perfect on this job, has anyone used the new miter clamps? If so, what do you think, tape, or clamp?
- image.jpg (73.42KiB)Viewed 1568 times
Ron Stigall
Superior Granite of Idaho
208-371-2349
superiorgranite@hotmail.com
208-371-2349
Re: Quartz
You could do either. I think having all your angles cut perfect and a good glue color will make the difference. Not so much your clamps/tape. One way is considerably cheaper and can warrant the same results in my opinion.
Josh Hartzog
Stoneworks
Hilton Head Island, SC
Stoneworks
Re: Quartz
I agree. I also think that with a rail saw you are going to be hard pressed to get that good consistent cut across that many slabs of quartz. It can be done, but it will be a LOT of work. Depending on where you are located, you could look at "partnering" with someone that has better mitering capabilities (saw, sawjet or cnc).VThartzog wrote:I think having all your angles cut perfect and a good glue color will make the difference. Not so much your clamps/tape.
Re: Quartz
Get ahold of Mar Meriux (sp?) with VT industries. This is exactly what they do and they do a good job with miters.
Re: Quartz
You lost me with the picture, that is a stepped edge?
Quartz is great to work with on miters. As mentioned, glue color is important. Subbing it out would be smarter than buying those miter specific clamps considering your situation.
If you want to fabricate it, for what it is worth I think the tape method sucks and the miter specific clamps are so overpriced it is borderline insulting to fabricators. You would never find something like that in the wood or metal industry at those prices. I don't mean to begrudge anyone a profit, but a made specific clamp that utilizes the same principles that you can do with 2 $4 clamps and a $5 square for the money they do is crazy.
Re: Quartz
If you can do a decent miter with stone you can do quartz using the same tools and methods. glue color is critical other then taht it is easier then stone and you can do it with a rail saw. We did it all the time before we got our cnc saw and a few times since.
K&D ENT.
Springfield TN.
Springfield TN.
Re: Quartz
I added the picture just because I wanted a picture up, we do very nice work. In the north west our little shop is looked down upon. Maybe because our prices per square foot is cheaper than the big shops.
Back to the point, we have done a few stone miters, and the tape works, just wondering if the miter clamps were faster, and done a better job at the corner?
Ron Stigall
208-371-2349
208-371-2349
Re: Quartz
I've seen miters done upside down, right side up, fancy clamps, cheap clamps, no clamps, tape, rail saw, CNC, bridge saw and probably every combination of the above. If the cut is good and the glue matches, then the miter should be good.
Fancy clamps seem like a waste to me, but if they work for somebody, who am I to tell them how to miter something up.
Re: Quartz
I work out of Boise, idaho. I actually have a three slabber going in at Kamiah.
Ron Stigall
208-371-2349
208-371-2349
Re: Quartz
Nick wrote:Andy Ross wrote:. If the cut is good and the glue matches, then the miter should be good.
This.......and tape sucks
So does poly
Re: Quartz
Ron, gotcha. I hear you, gotta get the fact you can fabricate out of the way. That is a nice job and certainly a pain by hand. It seems like you guys have miter experience but are you looking at getting away from tape because of what? speed, ease, or a better product? I would purchase a glue prematched to the quartz color you are using. That will go farthest for you off the bat with what you have. We don't do this but I did buy a close out of tenax POLY caesarstone match for blizzard and pure white. We used the blizzard color on a pretty large mitered kitchen and it was very convenient.
Chris, I have a general rule of attention span for me here. I only listen to and consider the advice of those who actually frequently fabricate/do/use what they are offering advice on. You don't qualify as offering me glue advice
Hey Ron, you should look into joining the SFA. You are actually getting more help than most from the general forum, but members can ask all kinds of questions and get many answers. For a shop age like yours, it would be a smart move.
Re: Quartz
GuyboR wrote:I agree. I also think that with a rail saw you are going to be hard pressed to get that good consistent cut across that many slabs of quartz. It can be done, but it will be a LOT of work. Depending on where you are located, you could look at "partnering" with someone that has better mitering capabilities (saw, sawjet or cnc).VThartzog wrote:I think having all your angles cut perfect and a good glue color will make the difference. Not so much your clamps/tape.
Ditto
Re: Quartz
Agreed.Andy Ross wrote:I've seen miters done upside down, right side up, fancy clamps, cheap clamps, no clamps, tape, rail saw, CNC, bridge saw and probably every combination of the above. If the cut is good and the glue matches, then the miter should be good.
We have done every way and don't necessarily have a set way. Myself on a simple 2 sided top and fairly small apron, I prefer face up and tape for the visibility and control of the joint.
IMO the clamps are too pricey and pretty cumbersome to be effective. As Nick stated, a $5 square and some clamps are cheap.
Re: Quartz
Nick, thanks for your reply, and I am seriously considering the cost of joining SFA. The advice is welcomed , and appreciated.
My quartz supplier hasn't mentioned the supply of color matching glue, and I know my local diamond tool supply guy doesn't
The poly color, any suggestions ?
Ron Stigall
208-371-2349
208-371-2349
Re: Quartz
Francinni Quartz , gun metal, arctic white,silver white.
Black galaxy, which will be easy, and a marble, 2cm new thassos.
I think I would need all the color matched epoxy except for the black galaxy, I'm thinking
The new thassos marble will be the hardest to fab.
Francinni buys the quartz, not sure the specific brand, probably china ?
Ron Stigall
208-371-2349
208-371-2349
Re: Quartz
Yeah, your not getting a color match for an importers "private line".
You will want a white base glue (we use tenax white), and not sure what "new thassos" is, but it may be that "white diamond/crystal thassos" that has been around in popularity as of late. If that is the case some kind of translucent glue will be necessary(we use tenax crystal)
We have mitered the crystal thassos/white diamond and although it obviously wasn't as super easy and consistent as real thassos, it was not as bad as it could have been by looking at it.
Re: Quartz
Nick, your right about the thassos marble. It like to blow out with any pressure, hard to work with, lots of TLC.
I also use the Tenax products, come to think about I think I have some crystal clear I got to fill a Carrara steam shower this past summer. My local supplier doesn't have the white Tenax, it's usually a yellow tint that he has, I'll ask him to get ome white.
Thanks for your feedback.
Ron Stigall
208-371-2349
208-371-2349
- Has thanked: 10 times
Re: Quartz
Ron wrote:I work out of Boise, idaho. I actually have a three slabber going in at Kamiah.
Holy SH@!... This is 10 plus hours of drive time!!!!
Jesse Arnzen
Lewiston, Idaho
Zen Stoneworks
Lewiston, Idaho
Zen Stoneworks
- graffster
Re: Quartz
Ron, call me I,m here in Boise may be I can help
George M. Graff SFA
Stone Pro Restoration & Repair Inc.
4741 Glenwood St. BLD. C
Garden City, Id. 83714
Cell 208-284-3984
Fax 208-853-2793
george@stoneproid.com
Cell 208-284-3984
Fax 208-853-2793
- Stonecuttter
Re: Quartz
Ron, you're obviously experienced, and also looking to raise your own bar insofar as quality... wanting to "get it right"... doing your best possible work. Just look at all the wonderful advice you got in the General Forum, and just IMAGINE all you'll learn in the "Members Lounge". Membership WILL be the best investment you could ever make for your business. This place, and these guys, have taught me SOOO much, and saved me SOOO much money it's ridiculous. I know most of the members will say the same. You have stuff for US to learn too, no doubt!!!
GET ALLIED! Learn, Share, Prosper! ...and if you can get to an SFA workshop, OMG, do it, man!!!
Sam Irvin
Pisgah Forest, NC
828-877-3765
proud and grateful SFA member!!!
http://www.sams-granite.com
Pisgah Forest, NC
828-877-3765
