Blick Pod suggestions for Breton CNC starter
Good Morning
I have my first CNC router arriving in a couple of weeks - a second hand Breton NC250.
I need to order a set of Blick Pods to get me started can anybody suggest what I need to get me up and running?
I'll be doing pretty standard sink and hob cutouts etc at the start and not edge profiling
Thank you
Thank you
Re: Blick Pod suggestions for Breton CNC starter
Get the biggest pods you can. We have a breton. The bigger the pods, the less you need, the faster the setup. Congrats on the machine!
Just make sure you know what height pods you need for your specific machine.
Startup Suction Cup List - Blick
3- 40mm x 300mm
3- 75mm x 300mm
8- 120mm x 120mm
4- 200mm x 200mm
8- 200mm x 300mm
6- 250mm x 500mm
2- Large Mechanical Clamps, Base is 200mm x 300mm
6- 50mm Pin Stops (a.k.a. locators, 2 sets of 3 - maybe 9 for 3 parts)
1- Stop Locator Tool
Optional
2- 75mm Round Core Drill Supports
2- 75x300 Core Drill Supports
A list I made up for someone years ago.
Jerry
3- 40mm x 300mm
3- 75mm x 300mm
8- 120mm x 120mm
4- 200mm x 200mm
8- 200mm x 300mm
6- 250mm x 500mm
Optional
Jerry
Jerry Kidd
Kidd Improvements Inc.
jerry@kiddimprovements.com
970-309-4339
970-309-4339
Lupo, I would look into the Green pods!
they are more cost effective and we offer all different sizes! New heights are coming out as well everyone!
Send me a pm and I can get you pricing!
- pods.jpg (127.71KiB)Viewed 442 times
- Been thanked: 50 times
Dear Lupo,
Typically, the Breton machines do indeed come with BLICK branded pods.
There is a standard package that we do in offers for machines that are meant to be a start up set.
Please write to me with your contact information and I'll send you an email with the suggested startup set.
gvanderbas@bretonusa.com
Gerry Van Der Bas
gerry@turriniusa.com
(708) 315-4875
Proven Solutions in Dust Collection & Water Treatment
World Class Equipment and Accessories for the Stone Industry
(708) 315-4875
Note that the Breton pods are a bit taller than the others.
G
G
Gerry Van Der Bas
(708) 315-4875
(708) 315-4875
If you can get Breton to swap pads do it. Started kit comes with too many small pods. Get the big pods from blick. Bigger pods = Les hoses. Breton height is 150mm. No green pods available in that height yet. You can probably use lower pods as the machine has enough stroke, just need to eliminate the standard height pods.
