Advice needed
- Mark Gamble
- Been thanked: 17 times
I am looking at a job with laminate tops. The 32" piece to the left of the fridge has cabinets coming down onto it. It is 5/8" laminate. My thoughts are to grind down the bottom to 5/8" or a bit less to slide it in under. The doors are at surface level so there are not many options that I can think of. The cabinet can't be removed due to crown. Anyone else had similar situations? What did you do?
Barrie, Ontario, Canada
Re: Advice needed
I never ground down the tops, I have found 2 solutions: Remove the crown to see if there is space to move the cabinet up, if there is not then cut the bottom of the cabinet to accomodate the counter sliding in, the doors can usually be moved up by changing the location of the hinges. Cutting the cabinet should be done with a Fein tool or similar, I put a piece of granite on both sides of the wood as a guide and cut away. Do it with extreme care and tell the homeowner that you may have to put a piece of trim on afterwards if the cut does not come out perfect.
Re: Advice needed
My advice is to not take on the problems of others, without charging appropriately for your time and assigning responsibility. I do not completely understand how this is a granite fabricator issue. It appears to be a client issue to deal with other trades. You really need to look at all the options with an open mind (including the crown molding). Everything that is put together can be taken apart. The owner should make the final determination on the course of the solution. I assume it would involve a wood guy of some sort (carpenter, cabinet maker, etc) I would defer the wood work to those who are well versed and have the right equipment.
Re: Advice needed
Dan, your advice is sound. I on the other hand have seen wood workers/ cabinet guys come in and butcher the cabinets to do a simple thing like this and charge good money to do it while I watched them, I determined I could do a better job, pocket the money myself and save the customer the grief of having to find someone else to perform the task. Since most of my work volume have changed to direct sales I have had to take on turnkey projects and not only it gives me control it also adds margins.
Re: Advice needed
I had to watch a guy cut in the cutout for a soapstone sink I made. . . with a Reciprocating Saw ! ! ! It took everything in me to shut my mouth. . . From then on. . . if it is not done ahead of time, I charge and do it right.
Joshua Schaefer
Creative Soapstone
Punta Gorda, Florida
http://www.creativesoapstone.com
http://www.coldstones.net
joshua@creativesoapstone.com
Office: 941.979.9480
Creative Soapstone
Re: Advice needed
Unless they are euros, I have cut the granite to the cab and just shims underneath the cab. If it will hit the door, then you can mill down the piece as you suggest, but the edge will be a problem.
- t-mobile
Re: Advice needed
I would approach with both dan and kens advice. I would look at removing and reonstalling crown, and raising the cab. It got in there somehow, and there is usually space. Some finish nails and wood putty, or paint can reinstall.
Bottom line though is you have to charge for all work.
In these times I take on alot of unusual things, and just charge accordingly. We have to be more than just a stone shop to not only survive, but to diversify and help with sales. At the end of the day, why should we not charge to any trade that helps us finish our work! Being in business is meant to make money, so when its on the table.... take it.
My 2cents.
My 2cents.
Tony Neylon
Delta Stone LLC
4664 Halls Mill Road
Mobile, Alabama 36693
(251) 660-1818
Delta1stone@yahoo.com
Delta Stone LLC
(251) 660-1818
Re: Advice needed
Charging is the key. Be rewarded for the risk that you take on. I am not suggesting that it can not be done, but you better know your own capabilities. On the job training can be potentially very expensive.
- t-mobile
Re: Advice needed
Yes it can! But if you dont leap, you never know.
Tony Neylon
Delta Stone LLC
(251) 660-1818
Delta Stone LLC
(251) 660-1818
Re: Advice needed
A step is one thing, a leap is all together different
Weigh the factors and take the appropriate step (or leap
- t-mobile
Re: Advice needed
Wisdom at its finest.
Tony Neylon
Delta Stone LLC
(251) 660-1818
Delta Stone LLC
(251) 660-1818
