Blanco Sinks
- chad201008
Is there a list to reference Blanco's old sink numbers to their new ones? I have all these .dxf files but no way to reference them to the new numbers.
Looking back, fifty years from now, don't you want to say you had the guts to get in the car!!
Chad Wennberg
Duluth, MN
Chad Wennberg
Duluth, MN
Re: Blanco Sinks
What's wrong with the new DXFs? (other than being in mm)
Use the newest files, and you can be better prepared if Blanco has made any changes to the sinks...
Re: Blanco Sinks
I got them from my blanco rep to be certain I had correct ones.
- topshop
Re: Blanco Sinks
You need to be vary careful with sink files. Every time the manufacturers need to rebuild their tooling the sink shape may or maynot change and they don't always tell you when they have done that. Sometimes the tooling has gotten crashed and need to be rebuilt without notice. The latest files should be the good ones but not always.
Re: Blanco Sinks
I was never able to get a cross reference list, BUT...What I do is put the new model number (from catalog) into the search engine on the Blanco website, then open the spec sheet. The spec sheet still has the old numbers on it. Then you just do a save as on your dxf files with the new numbers.
Re: Blanco Sinks
we've probably done 3 styles since the model changes. They have been the same template.
Wayne Fajkus
Granite by Design, Inc
(512)932-2346
(512)932-2346
