waterproof labels for stone...
I am looking for labels to put on the pieces of a job when they are cut so that the saw guy can write the customers name and also if it is part 1 of 4, 2 of 4, etc and I want them to be able to stay on the stone during the fabrication process so that when the install guys load up, there is no confusion and no pieces left behind. I was thinking about just using duct tape, but some stones can be damaged by duct tape, so we would need to be careful to make sure we did not use it on those stones.
does anyone have anything they are using now?
Re: waterproof labels for stone...
We used to use a white out pen for this. But now there is a drawing that goes with the job to install that shows all the pieces including splash, stove fillers, and any particular notes about the job. This has worked better than the names on the pieces for us.
but the blue tape would work great too. Always got that stuff laying around, we do.
Agreed! Shop drawing for the shop. Another one for install crew. We also have a checklist for both as well. This has solved these problems by about 99%ash20ash wrote:We used to use a white out pen for this. But now there is a drawing that goes with the job to install that shows all the pieces including splash, stove fillers, and any particular notes about the job. This has worked better than the names on the pieces for us.
I agree to All of ur suggestion ,only suggestion i can say is i do write the info behind the stone (back of the slab) .most of theshops i went they dont care about the surface coz most of the time they uses a white grease pencil on a dark quartz stone or black pencil on the light stone.
Mark Vhirne Castillo
SFA Member
MV Castillo Contracting Inc.
Edmonton,Alberta Canada
780.907.2524
Mahboo780@yahoo.ca
SFA Member
780.907.2524
Mahboo780@yahoo.ca
- Dan Dauchess
- Been thanked: 10 times
We laser print sheets of labels for our slab/remnant inventory on these.
http://www.amazon.com/Avery-Weatherproo ... oof+labels
We write information with Sharpies. Only drawback is that the Sharpie ( not the laserprint) fades in 4-6 months in the summer sun.
Dan Dauchess
Signature Stone
256 Industrial Blvd.
Toano, VA 23168
http://www.signature-stone.com/
ddauchess@signature-stone.com
Signature Stone
Toano, VA 23168
We put a label on the edge and a little bit of silicone on it
Andres Santana
Gramarte SAS
phone: (57) 1 4936943
address: Cr 20 168-30
Bogota-Colombia
Gramarte SAS
Bogota-Colombia
we use some kind of water proof label the kind for laser printers and use black sharpie , been using them long time , they don't leave residue on the stone
Yep we also have shop drawing and a single sheet with all information and office drawing
Stucco Tape. it's like vinyl. The residue wont stick and be a problem, you can write on it with a marker, it's red, and you can peel it off easily. It wont deteriorate in the rain.
thanks guys! I will try the tape and labels, and if that does not solve it, then we will go with the drawing idea.
Hey Guys! We have been working on this and have a prototype tape that leaves no residue and can be written on with a sharpie. You can also customize a paper label and fasten it directly onto the slab with the tape since it is clear and waterproof. This makes it applicable to any color of stock you can think of. We are looking to market this at about $16. It comes in a lined roll that is 4" wide by 35' long. I would love to have a few of you try this out and let me know your thoughts! I might be able to arrange a free sample or 2 to anyone who feels like being a guinea pig! Call me with any questions: Kip @ Salem Stone 800-234-1982 x217. I look forward to hearing from you!
Kip Crabbe
Sales & Service Associate/Owner
Office: 800-234-1982 ext.209
Direct: 336-201-5414
Fax: 336-778-3113
www.salemdist.com
SALEM Distributing Company, Inc. | | ,
Success. Delivered.
Fax: 336-778-3113
www.salemdist.com
Success. Delivered.
KCrabbe wrote:Hey Guys! We have been working on this and have a prototype tape that leaves no residue and can be written on with a sharpie. You can also customize a paper label and fasten it directly onto the slab with the tape since it is clear and waterproof. This makes it applicable to any color of stock you can think of. We are looking to market this at about $16. It comes in a lined roll that is 4" wide by 35' long. I would love to have a few of you try this out and let me know your thoughts! I might be able to arrange a free sample or 2 to anyone who feels like being a guinea pig! Call me with any questions: Kip @ Salem Stone 800-234-1982 x217. I look forward to hearing from you!
we can test some if you'd like. We don't get much rain, but we get 115+ here in the summer and everything likes to get brittle and difficult to remove.
Kip,
Is it UV stable...ie...does it prevent the sharpie from fading in the sun?
Send me a roll and I'll give it a try also.
All my stock is outside- feel free to use and abuse me
Michigan climate
Hey Tim! I will send you a few feet to try out. I welcome your feedback. Guy - I think it is UV stable, but I will have to confirm it with the manufacturer. We put it on some stock and left it out for a while and so far there is no fade at all. We are also working on a tinted version that would be more visible if needed. Send me your mailing address and I will be happy to send you a few feet also. This goes out to you too, Andy and Cameron, as well as everyone else until my samples are depleted. kcrabbe@salemdist.com I also wanted to correct a previous error...the rolls are manufactured in 35 METERS, not feet. More for your money!!
Kip Crabbe
Fax: 336-778-3113
www.salemdist.com
Success. Delivered.
Fax: 336-778-3113
www.salemdist.com
Success. Delivered.
Kip, for $16, just send (& invoice) me a roll of it, please. It sounds like a great place to start!
thanks.
thanks.
Will do Dan. I will do that first thing Monday morning. Thanks!
Kip Crabbe
Fax: 336-778-3113
www.salemdist.com
Success. Delivered.
Fax: 336-778-3113
www.salemdist.com
Success. Delivered.
Same here.Dan R. wrote:Kip, for $16, just send (& invoice) me a roll of it, please. It sounds like a great place to start!
thanks.
You got it, Guy!
Kip Crabbe
Fax: 336-778-3113
www.salemdist.com
Success. Delivered.
Fax: 336-778-3113
www.salemdist.com
Success. Delivered.
Thanks Chris! Expect to hear from me again tomorrow!
Kip Crabbe
Fax: 336-778-3113
www.salemdist.com
Success. Delivered.
Fax: 336-778-3113
www.salemdist.com
Success. Delivered.
Same here please!Dan R. wrote:Kip, for $16, just send (& invoice) me a roll of it, please. It sounds like a great place to start!
thanks.
If it's easier you can just bill Dan for mine too!
- Been thanked: 90 times
Same here.Kip, for $16, just send (& invoice) me a roll of it, please. It sounds like a great place to start!
Steven Nenzel
Rock-It Surfaces
947 Rancheros Dr
San Marcos, CA 92069
760-597-1800
steven@rockyourhome.com
www.rockyourhome.com
Rock-It Surfaces
947 Rancheros Dr
760-597-1800
I received my roll....but much like Dan's process of evaluating product, it is sitting on my desk getting acquainted with our company for a while.
