Vanity Sink Over Hang
Had an install where the customer had complaints about the 1/4 inch over hang on the vanity under mount sink, said that shes been to all the local home depots in her area and all are flush tho the sink . We have been doing the same 1/4inch over hang for over 10 years. Mainly so there is no reveal on sink and therefore no maintenance on silicon. Can i hear some opinions please.
Anastacio ortuno
IQ Granite & Flooring
1306 Washington st
S Houston,Texas 77587
(O) 281-888-7558
(C) 281-904-1781
IQGRANITE.HOUZZ.COM
IQGRANITE@GMAIL.COM
1306 Washington st
(O) 281-888-7558
(C) 281-904-1781
IQGRANITE.HOUZZ.COM
IQGRANITE@GMAIL.COM
Re: Vanity Sink Over Hang
What make and model sink?
Our policy....we cut to the manufacture's cutout. There is a reason that they spec such a cutout and therefore that is what we use.
I agree sink was a kohler 2209 that is what my reply was to customer, that all we do is cut the under mount hole to the manufacturers template therefore resulting in an acceptable finished look.
Anastacio ortuno
1306 Washington st
(O) 281-888-7558
(C) 281-904-1781
IQGRANITE.HOUZZ.COM
IQGRANITE@GMAIL.COM
1306 Washington st
(O) 281-888-7558
(C) 281-904-1781
IQGRANITE.HOUZZ.COM
IQGRANITE@GMAIL.COM
I always cut them with an overhang mostly because a lot of these sinks are not finished all the way up to the flange if you cut them flush you run the risk of having unfinished porcelain exposed plus its less maintenance on the sealant if its not exposed to the water all the time
Jack O'Connor
Owner
O'Connor Fabrication,
Palmdale CA
661-810-7836
Owner
Palmdale CA
661-810-7836
Tell her to call Kohler and ask them how it should be mounted, if that doesn't satisfy her then nothing will. Vanity sinks are not like kitchen sinks, there is no flush or reveal option in porcelain. People are nuts.....
- Dan Dauchess
- Been thanked: 10 times
x2Nick wrote:Tell her to call Kohler and ask them how it should be mounted, if that doesn't satisfy her then nothing will. Vanity sinks are not like kitchen sinks, there is no flush or reveal option in porcelain. People are nuts.....
The Kohler template has overhang for a reason.....
Dan Dauchess
Signature Stone
256 Industrial Blvd.
Toano, VA 23168
http://www.signature-stone.com/
ddauchess@signature-stone.com
Signature Stone
Toano, VA 23168
The vitreous china sinks are a fired-clay product. Even though they all come from the same molds, they to have some (very slight) warping and shrinking as they dry and are subsequently fired. I believe that the overhang is to account for those variances.
- Been thanked: 90 times
The bowl shape can vary quite a bit and that is why the manufactures have such a large over hang into the bowl.
Steven Nenzel
Rock-It Surfaces
947 Rancheros Dr
San Marcos, CA 92069
760-597-1800
steven@rockyourhome.com
www.rockyourhome.com
Rock-It Surfaces
947 Rancheros Dr
760-597-1800
Thanks for all the info I appreciate your comments
Anastacio ortuno
1306 Washington st
(O) 281-888-7558
(C) 281-904-1781
IQGRANITE.HOUZZ.COM
IQGRANITE@GMAIL.COM
1306 Washington st
(O) 281-888-7558
(C) 281-904-1781
IQGRANITE.HOUZZ.COM
IQGRANITE@GMAIL.COM
- mark brooks
i did a house that had 5 2210 sinks...3 were from Mexico ,2 were from veitnam...the pattern fit the mexican sinks just fine but the veitnam sinks were way rounder and through off the over hang in the front and back..we made a quick run to a big box store and found 2 more mexico made sinks and all was good again...didnt see that coming
Mark Brooks
Red River Stone
Heber Springs,Arkansas
(870)-213-7652
Red River Stone
(870)-213-7652
- Has thanked: 28 times
Ive tried to cheat that 1/4" back to 1/8" and you will have a mess. White silicon will usually hide it pretty well. The paint doesnt go all the way up on the flange. Show her that and explain it. If she still wants it, do it and leave her with the mess.
